Mustang Forums at StangNet
The Offical 1990Coupe progress thread
This is a discussion on The Offical 1990Coupe progress thread within the 5.0 Talk forums, part of the 5.0 Mustang category; Originally Posted by 1990Coupe the NRC brackets included fittings for the softlines on the calipers. meaning i can cut the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Talk
Over 151,000 Members!!
Reply
  #51 (permalink)
Old 07-25-08, 03:24 PM
SVT32VDOHC's Avatar
waiting for the next hack attack
Quote:
Originally Posted by 1990Coupe View Post
the NRC brackets included fittings for the softlines on the calipers. meaning i can cut the hardlines , and put these fittings on them, but the fittings they included do not fit the softlines on the calipers.. Another reason i think these differ from those years.. These rear brakes are from a 99+ car right SVT?
Oh shoot I though you meant on the front calipers...I looked at fronts...sorry. The rears are the same. They hook up the same, and they mount the same on 94-04 Mustangs. If you cut the hard line on the rear end....you will have to get a flaring tool and reflare that line after you slide the threaded screw-in peice on there.
  #52 (permalink)
Old 07-25-08, 03:32 PM
1990Coupe's Avatar
there's nothing cool to put right here
Quote:
Thats what i planned on doing - reflairing the line. I may have to improvise my own setup when the time comes, and the rear is in the car. I'll be sure to document this because even SN95brakes.com (which has a new URL its not this one anymore) doesn't specifically speak about this at all..
  #53 (permalink)
Old 07-25-08, 07:33 PM
SVT32VDOHC's Avatar
That sucks that they don't tell you about it, but I know you will figure it out. Once it's in, you're in....so don't worry about it. I wish I wouldn't have worried so much about stuff with Hack Job. When that day came, I conquered!!
Any work planned this weekend??
  #54 (permalink)
Old 07-25-08, 07:45 PM
5.0Droptop's Avatar
Neutered Member
to much yak yak yak and not enough pictures.
kthnx
  #55 (permalink)
Old 07-26-08, 12:13 PM
1990Coupe's Avatar
The Heart
Its out of an 89 mustang. It only has 67k miles on it!
  #56 (permalink)
Old 07-26-08, 01:18 PM
SVT32VDOHC's Avatar
Looks like you got everything you need. Accessories are there....flywheel is there, driveshaft, bell housing...Is that wiring I see?????
Hell yeah bro. So let me guess....the next pictures are going to be of you painting the block, accesories, intake and valve covers?? Make sure you replace the water pump, it's cheap insurance. Put a little anti seeze on the threads of the bolts when you reinstall it. And don't break off the old ones in the block...use hand tools, no air tools on water pump bolts!!!
Nice!!!!!!!!!!!!!
  #57 (permalink)
Old 07-26-08, 07:17 PM
1990Coupe's Avatar
Actually the motor will sit for a few weeks. I'm going to get the trans tomorrow, and continue stripping the engine bay. Then after that, its on to pulling the dash for the heatercore swap. I may need you for other things, when i find out a list i'll send u a PM
  #58 (permalink)
Old 07-27-08, 10:42 AM
SVT32VDOHC's Avatar
Sounds good, I'll be here.
  #59 (permalink)
Old 07-27-08, 01:24 PM
25thmustang's Avatar
Official Member
Definately get that motor all dolled up, but stock looking. I think a clean fresh stock engine bay can be one of the best looking types. Keep up with the pics and progress!
  #60 (permalink)
Old 07-27-08, 05:18 PM
ryan218's Avatar
In just 10 years, I'll be old enough to drive!!!!
Quote:
me too..smoothing it and all looks good. but a clean stocker looks best to me imo.
  #61 (permalink)
Old 07-28-08, 08:43 AM
1990Coupe's Avatar
Quote:
I was going to do basic wire-hiding in the fenders should i not? I'm NOT going to smooth out the engine bay.. Maybe i should keep the wires visable and NOT hid them. replace all the loom so they look new
ON another note, picked up the tranny yesterday
But now i'm broke And there is a million odds and ends i still need to get. But nothing "HUGE"..
  #62 (permalink)
Old 07-28-08, 11:52 AM
fiveohlxhatch's Avatar
Coming along nicely. I'll be curious to see your input on the softline to hardline issue for the rear discs. I've done the 5-lug for my brother's car but we stuck with rear drums. Can't wait for more pics!
  #63 (permalink)
Old 07-28-08, 02:10 PM
SVT32VDOHC's Avatar
Hiding the wires can be a PITA, just because you have to route them in a way where they will not rub through, and also hope they are still long enough. I would do just what you said and put new black looming on them so they look fresh.
  #64 (permalink)
Old 07-28-08, 04:05 PM
Official Member
New loom would be perfect. Don't even go through the effort of hiding, just make it look like a clean stocker.
  #65 (permalink)
Old 07-28-08, 04:31 PM
1990Coupe's Avatar
I was going to hide it all.. Coming from you guys, your opinions I take into great consideration. This i think i will do
  #66 (permalink)
Old 07-28-08, 04:46 PM
SVT32VDOHC's Avatar
If you want to hide one harness...the headlight harness is the easiest to hide. You can simply run it through the core support. I saw it on this project car a shop near by was doing. The opening is big enough, and it gets the readiator, fan, and condensor area cleaned up. No fabbing is needed, or lengthening of wires....just a thought.
  #67 (permalink)
Old 07-28-08, 05:34 PM
Official Member
Yeah, I just think hidden wires and all those holes looks worse than with the wires all clean and and in the stock location. Under hood should just look clean and factory original!
  #68 (permalink)
Old 07-29-08, 06:03 AM
1990Coupe's Avatar
Thanks Fellas! Thats this weekend's project Here is some more progress, not too much but its progress..
Here is the Trans
PS. I can't unbolt the drivers seat. The rear two bolts are covered up by the seat track since its electric and all the way back. Bummer
  #69 (permalink)
Old 07-29-08, 06:19 AM
Official Member
I'm still amazed a 4 cyl came with power seats... Did you try hitting it with a fresh battery and getting it to move?
  #70 (permalink)
Old 07-29-08, 07:26 AM
1990Coupe's Avatar
haha i know! the problem is i stripped most of the wires from the engine bay over the weekend. All i have left is some vac lines and to pull the computer/harness. I'll have to work around the seat i guess
25th how did you guys make out at Pinks this weekend???!?!?
  #71 (permalink)
Old 07-29-08, 11:40 AM
SVT32VDOHC's Avatar
That carpet will clean right up. My Titanium grey carpet in my 91 notch was coffee stained, dog hair, gum etc....1990....2 words...Greased Lightning!!! Purple bottle, scrub brush and the hose (power washer is better if you have one) Mine came out like brand new. Where did you find the trans??
  #72 (permalink)
Old 07-29-08, 11:48 AM
1990Coupe's Avatar
I'll remember that!!
I found the tranny through a guy i met at the mustang boneyard that is a few miles from my house. He gave me his number and said he has something for me. When i got to his house he had that - i paid more then i had wanted but he said its a perfect working trans, and said if there is an issue with it he'll take it back and refund my money. (signed paper makes it a contract ) It "looks" like its in good shape.
  #73 (permalink)
Old 07-29-08, 04:13 PM
Official Member
Sister, dad and brother got interviewed and the car got looked over by the camera crew. On the pass with Rich hand dropping it, I know the camera was focused on the car, I guess they liked it being a stick car.
Didn't make the show, that was a high 9s class, but still had a good time. Car went 10.33 into a head wind and who knows on the hand drop pass, they dont give a timeslip.
  #74 (permalink)
Old 07-29-08, 04:55 PM
SVT32VDOHC's Avatar
That's great he said he'll take it back if there is a problem. Hopefully you will get it together and running soon, so you will know. Once the engine bay is painted you should have the car running in a few more working days afterwards. My 5.0 swap went well. Can't wait to see more pics.
I tell ya....I have seen so many cool blue this week and last, driving around delivering parts!!! I can't believe how many blues are out there. My favorite is that new GM blue that is on Corvettes, G8's and Cadillac XLR's....It's siiick!
  #75 (permalink)
Old 08-01-08, 07:52 PM
SVT32VDOHC's Avatar
*SVT32VDOHC ninja jumps Coupe's progress thread to the top so it's easy for him to find this weekend when he updates us on the heater core and engine bay work!!!!!!!!*
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
