View Single Post
  #12 (permalink)
Old 07-28-08, 02:43 PM
bhuff30's Avatar
bhuff30 bhuff30 is offline
04GTMustang is on track. Run the widest gap that your ignition system can support. You will know that you should decrease the gap if you get a mis-fire/spark blow out at full load. So run the stock gap. If it misses, then decrease the gap.
As for plugs, it won't hurt to run a colder plug. If the plug is too cold, you'll get a miss at idle because the plug will foul.
