Mustang Forums at StangNet
Vacuum Leak? Sucking Noise. 96 GT
This is a discussion on Vacuum Leak? Sucking Noise. 96 GT within the 4.6 Tech forums, part of the 4.6L Mustang category; I have a 96 GT, pretty much stock. The only power plant modification that has been done is had a ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-29-08, 08:54 PM
I have a 96 GT, pretty much stock. The only power plant modification that has been done is had a BBK Cold Air Kit installed. Currently when the car is running there is a very loud hissing noise coming from the engine. I have checked the PCV valve hose which runs to the intake, the vacuum reservoir under the right front fender, remounted the intake and still there is this very noticeable and very loud hissing noise. The noise does not change pitch or intensity as the engine turns higher RPMs. I'm at a complete loss as to what this is coming from. Any ideas or suggestions would be greatly appreciated.
  #2 (permalink)
Old 07-29-08, 09:17 PM
Superhereaux's Avatar
chicks make me feel inadequate
Did the noise show up after the kit was installed?
  #3 (permalink)
Old 07-29-08, 09:25 PM
To this i could not tell you. The kit was already installed on the car when I bought it. I have taken it off and reinstalled it myself without any change in the noise.
  #4 (permalink)
Old 07-31-08, 02:52 PM
any ideas?
  #5 (permalink)
Old 07-31-08, 06:51 PM
99GrandTouring's Avatar
A trick we use everyday in the shop to find intake leaks is to start the vehicle get a can of throttle body /carb cleaner (must be 02 sensor safe) and slowly start spraying over the areas of the intake that could be possibly leaking (around the gaskets, vacume lines, esp vacume line connection) you will notice the idle of the vehicle change when you find the leak, to make 100% for sure stop spraying let it start ideling as normal then just hit the spot again where you think the leak is, if it acts up again then theres your leak.
Hope this helps.
  #6 (permalink)
Old 08-01-08, 08:54 AM
blckstng96's Avatar
Official Member
the carb cleaner trick works but anyway i had this same problem with my 96 and couldnt figure it out for anything.well i popped the upper intake plenum off,no big deal 4 bolts and on the underside of it there is some sort of screw/plug the screws in there near where the throttle body mounts and mine was backing out for some reason,screwed it in tight and never had the problem again.check into it.i couldnt find mine with the carb cleaner though.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
