Mustang Forums at StangNet
delay in throttle response
This is a discussion on delay in throttle response within the Other Auto Tech forums, part of the General Automotive Forums category; my explorer has had a delay in throttle response ever since i picked it up about 7-8 months ago. i ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-01-08, 06:56 AM
RedDaemon's Avatar
Official Member
my explorer has had a delay in throttle response ever since i picked it up about 7-8 months ago. i thought this would have been fixed when my explorer went in to get its transmission rebuilt this past weekend. however it is still present
i was thinking it might be the TPS. should i try recalibrating it or should i replace it. anyone have a price on a 95 explorer v6 TPS? or would it be better to replace the whole throttle body?
should i consider another cause as well?
  #2 (permalink)
Old 08-01-08, 12:23 PM
Gearbanger 101's Avatar
SuperMod
Canadian Colossus
Before I replaced anything, I would consider a tune up. Do the basic maintanence stuff first, then dive into replacement parts. What kind of mileage is on it? At the very least, new air/fuel filters and spark plugs should be done. It could be the TPS sensor...they do go bad from time to time. If I recall correctly, the TPS on the 4.0L OHV is about $60 to replace....the same as a 5.0L. Might wanna give the Mass Air Meter a quick clean up as well. The can read all over the board when the wire element gets contaminated with road oil and dirt over the years. Try that and let us know.
  #3 (permalink)
Old 08-01-08, 12:49 PM
RedDaemon's Avatar
Official Member
Quote:
the car has 111,300mi on it
the previous owners claimed to have given it a tune up.
changing plugs on this engine looks to be really complicated.
i replaced the fuel pump 300mi ago so i know things are good on that end. air filter was also replaced not too long ago as well. is the TPS sensor something i should go ford oem or can i pick up the napa alternative? ill see what i can do with the mass air meter.
how likely is it that the throttle cable is "sticking". i cant go out and look since the car was actually brought back to the transmission shop for a small leak.
  #4 (permalink)
Old 08-01-08, 12:51 PM
SuperMod
Canadian Colossus
A sticky throttle cable shouldn't cause hesitation though? Maybe a hanging idle. As for the TPS, I would go with genuine Ford. When it comes to the small electronic sensors, I never trush anything other than OEM.
You ever run it for codes?
  #5 (permalink)
Old 08-01-08, 02:08 PM
RedDaemon's Avatar
Official Member
idk, just throwin out ideas haha.
i got a buddy with an xcal2. ill see if i can borrow it
  #6 (permalink)
Old 08-01-08, 02:31 PM
SuperMod
Canadian Colossus
Quote:
I'm not 100% sure it will work. If I recal, your year Explorer was kind of a half breed between the OBD1 and OBD2 set up. It will have the OBD2 port under the steering column, but it does not utilize the OBD2 computer. I believe there is a second port under the hood that is OBD1 EEC IV compliant....in which case your friend XCal II won't work. Just head over to Autozone and have them read it for free with an early OBD1 tester.
  #7 (permalink)
Old 08-01-08, 10:15 PM
RedDaemon's Avatar
Official Member
they do it for free? hot damn!
i gotta go over there anyway. thanks for the suggestion
  #8 (permalink)
Old 08-02-08, 03:19 PM
RedDaemon's Avatar
Official Member
wow i am pissed. advance auto does not read obd-1 codes in my area. i also checked wit ha bud upstate that works at an advance auto and he said his place doesnt read them either.
  #9 (permalink)
Old 08-02-08, 04:27 PM
SuperMod
Canadian Colossus
Might have to hit the local Ford dealership and see if they've got an old school STAR tester laying around. Doubt they'll do it for free though? Either that, or you could break down and buy yourself one. Look online, the old OBD1 set ups aren't that expensive.
Here's one that won't kill your budget....http://www.toolsource.com/digital-fo...ourceid=nextag
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
