Mustang Forums at StangNet
Charge/Voltage indicator help needed
This is a discussion on Charge/Voltage indicator help needed within the Fox 5.0 Tuning forums, part of the 5.0 Tech category; OK, I had my turbo installed and my main ground was loose. The smaller wire fried and I replaced the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-03-08, 10:09 PM
rdharper02's Avatar
Official Member
OK, I had my turbo installed and my main ground was loose. The smaller wire fried and I replaced the whole lime (while cleaning and re attaching the main). Now my gauge is only reading about 10 volts. Does anyone know where this gauge reads from? Is my battery or alt bad? The car runs fine, but the Wideband is dipping into the 11 range (believe the tune was done with the bad ground). I'm going to have the guy re-chip it, but need to figure out if it is my battery or alternator that is showing the low voltage. Seems to be the battery (once started, runs fine), but the location of the voltage circuit will help me determine the source. Any help or ideas are welcome.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
