I am converting to a auto th400 so I have the following for sale and would like to sell all together but may split up parts.
This trans is the same trans used in the 1995 Cobra R.
Tremec 3550 transmission has less than 10k on it. Shifts perfectly with no grinding at all. perfect conditions solid trans.
Pro 5.0 shifter.
Spec stage III clutch and Spec Aluminum flywheel with 0 oz, 28oz, and 50oz bolt on weights for different balances. Clutch and flywheel have about 450miles street miles on them.
Lakewood blowproof bellhousing for sbf engines, this is a scattershield and has the engine plate and grade 8 bolts.
Extended clutch fork for use with lakewood bellhousing.
UPR tripple hook quadrant, UPR firewall adjuster, UPR adjustable clutch cable.
Engergy suspension poly urithian trans mount.
I also have a brand new in box ford racing king cobra clutch to sell seperately $150.00 for tremec 3550 or t5 applications.
This setup will bolt directly into your fox or sn95 mustang with sbf 302/351w motors.
$1300obo
Email at
Steedafied@aol.com email for questions or more pics. thanks.
I am in IL nw suburbs of chicago.
