Mustang Forums at StangNet
Help with startup
This is a discussion on Help with startup within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; After 4 years, I finally got this thing ready to start. I start it up for the first time after ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-09-08, 04:50 PM
TrueBlue95GT's Avatar
Official Member
Help with startup
After 4 years, I finally got this thing ready to start. I start it up for the first time after fixing a couple of vacuum leaks and I can't get it to stay running. I need help. It will crank for a couple of seconds, fire and rev up to 4000rpms for one second and then immediately die. What should I mess with first? Also, does anyone know where I can get a flow chart for my 80mm Pro-M?
  #2 (permalink)
Old 09-10-08, 09:44 AM
Stanger007's Avatar
What's your startup tune look like?
Wes
  #3 (permalink)
Old 09-10-08, 08:10 PM
Official Member
My point exactly. What values do I need to mess with to get this thing to keep running in startup mode. I've read alot since I posted this question. The crank settings are ok because it fires right up, but once it goes into the "startup" settings, it falls on its face. Even when I give it gas, it wants to die. Would my logic be correct in saying that this means that it is running lean or is it that the timing is off? The timing is at the stock 10*. Do the MAF settings need to be changed or should I look more towards the IAC settings?
  #4 (permalink)
Old 09-10-08, 08:43 PM
Stanger007's Avatar
Here's a few more questions for you...
Is your MAF calibrated for the 42s? Fuel pressure at 39psi with the vacuum off? What's the specs on that cam?
Wes
  #5 (permalink)
Old 09-10-08, 09:16 PM
Official Member
The MAF is calibrated for 42lbers and the fuel pressure is 39psi plus or minus 1 with the car off because I haven't been able to set the pressure with the car on. The cam has around 600 lift but the lsa is 113* I believe.
  #6 (permalink)
Old 09-11-08, 07:03 AM
Stanger007's Avatar
I sent you a PM.
Wes
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
