Mustang Forums at StangNet
Engine hesitation and no HP
This is a discussion on Engine hesitation and no HP within the V6 Talk forums, part of the 94-04 V6 Mustang category; Have a 95 v6 that has baffled every mechanic that has looked at it. Car has hesitation issues accompanied by ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-09-08, 08:36 PM
Have a 95 v6 that has baffled every mechanic that has looked at it. Car has hesitation issues accompanied by spark knock and there is a total lack of hp. The worst part is after the car slows down (but doesn't come to a complete stop) and then tries to accelerate again. The car will not accelerate for anywhere between 5-25 seconds and then it will SLOWLY begin to increase speed. Transmission expert says it is not transmission, engine expert says it is a fuel starvation issue. Any ideas?
  #2 (permalink)
Old 09-09-08, 08:41 PM
Skymarshal's Avatar
Official Member
Replacing the fuel filter is a cheap thing to try.
  #3 (permalink)
Old 09-09-08, 09:43 PM
Already replaced fuel filter
Quote:
I've replaced the fuel filter, fuel pressure regulator, camshaft sensor and crankshaft sensor. Was thinking about replacing the fuel pump. The fuel pump tested at 31psi at idle which is low but still within the acceptable range (30-45psi).
  #4 (permalink)
Old 09-12-08, 06:15 PM
Mustang5L5's Avatar
Garage
No engine codes at all?
  #5 (permalink)
Old 09-12-08, 07:39 PM
Quote:
Thanks for the reply. Not a single engine code has come on. The last engine codes came on about 3 years ago after replacing my EGR valve (excessive flow detected at EGR and No flow detected at EGR).
  #6 (permalink)
Old 10-02-08, 07:43 PM
Took my stang to another transmission specialist and he drove it around. In his opinion he thought that the transmission was working properly and that all of the problems the car is having is due to a computer issue. He thought that the computer might need a calibration update. Anyone ever heard of this?
  #7 (permalink)
Old 10-02-08, 07:59 PM
03v6's Avatar
ECU.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
