OK I'll try to be as brief as possible..
I am running the Anderson Motorsports PMS w/ the Uego 2000 air flow meter.
The motor spec's
347
trickflow box R intake
Abaco mass air
75mm TB
30lb injectors
RHS 200/64 cast heads
Comp Cams @.050 lift Intake 224 Exhaust 236 lobe seperation 114.0
I am running it on pump gas..
Now for the questions...
I am getting the typical surging in the motor at idle and going down the road after I let off of the throttle. What is causing this?
I can not get it to level out under min load. the car starts "bucking" this happens more frequently at lower RPM's, if I run it at 3800RPM and up it still shows up once and while but not as frequently.. the timing is showing up on the computer as jumping from 4 degrees to 35 degrees and will not settle down. this happens at idle and at part throttle. What do I need to look at or change to help with this problem?
I could keep going on but this is a starting point, I hope someone else can help me try to figure out what is going on.
