Mustang Forums at StangNet
QUARTER WINDOW ADJUSTMENT 66 CONV.
This is a discussion on QUARTER WINDOW ADJUSTMENT 66 CONV. within the Classic Tech forums, part of the Classic Mustangs category; I need to adjust my rear quarter windows. Any help or tips on this task would be greatly appreciated. Thanks, ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-18-08, 03:20 PM
I need to adjust my rear quarter windows. Any help or tips on this task would be greatly appreciated. Thanks, Jim
  #2 (permalink)
Old 09-19-08, 01:27 AM
Official Member
Of course you will be limited by the top as it's cut, stapled, and glued to the carriage, but you should try to get the top relatively square for a starting point.
After that the quarter window is relatively simple (if not satisfying for a perfectionist), with the three bolts at bottom plus the two up top giving you most of the adjustment (there is also a stop for the regulator that should be loosened). Get it to fit snugly up top, tighten the bolts, and then roll it down and see how it fits. With a proper top/carriage alignment, I think you will get a pretty good result, but with a third, fourth, or moreth iteration top the fit may be a matter of compromise. It took me about six attempts to get relatively happy with the fit between the top and the quarter window, and longer once the door window was part of the mix.
  #3 (permalink)
Old 09-22-08, 06:15 AM
Marshall's Avatar
Other_shoe can you tell me if one can adjust the quarter window to line up with the door window? Mine is close at the bottom but a gap at the top. I cant see how to adjust this.
Thanks
Marshall
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
