Mustang Forums at StangNet
Transmission yolks: difference between C4 and AOD?
This is a discussion on Transmission yolks: difference between C4 and AOD? within the Classic Tech forums, part of the Classic Mustangs category; I'm swaping my C4 out for an AOD and I need help understanding the differences between the two yolks. The ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-21-08, 06:40 PM
calpolymustang's Avatar
Official Member
I'm swaping my C4 out for an AOD and I need help understanding the differences between the two yolks. The AOD, which came from an '88 Lincoln Mark VII, has what looks like a harmonic dampner on it. Is this needed for the AOD? or is it only used when using the Lincoln driveshaft. II prefer to use the original '66 driveshaft.
I will be installing the AOD this week and will check to make sure I still have about 1" of play between the yolk and the tailshaft.
  #2 (permalink)
Old 09-21-08, 08:57 PM
The damper isn't needed. You can remove that part of the yoke using a BFH. That said, some AOD's use a 31 splined sized yoke (outer diameter) with a 28 spline inner. Otherwise the C-4 yoke will work.
  #3 (permalink)
Old 09-22-08, 01:28 PM
Tubo(2-bo)'s Avatar
Official Member
Use a T-5 Yoke, its the strongest of the bunch & you wont need to do anything to your 65-66 DS. You will need a universal joint thats specific to the swap. T-5 yoke & DS yokes have a different width.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
