View Single Post
  #1 (permalink)
Old 09-14-08, 02:39 PM
Mustang5L5's Avatar
Mustang5L5 Mustang5L5 is online now
Garage
Sn95 steering wheel into 87-89 Fox
So I'm attempting to install an SN95 steering wheel onto an 87-89 tilt column.
Anyway first things first. yes, it does bolt up.
Here's a shot from the side. The SN95 wheel is taller than the 87-89 wheel, so you'll notice the turn signal lever is slightly further away. Also, you'll notice color match is slightly off. This was an 94-98 Black wheel, and it was slightly darker than the 87-89 column trim. Also, i did not have the wheel bolted up all the way. It will move back about 1/4" from where it is in this pic. The stock tilt column trim fits into the space behind the wheel, so it looks acceptable
