Mustang Forums at StangNet
Fixed bucking problem!
This is a discussion on Fixed bucking problem! within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; I have two cars with Tweecers. One is a TT '65 FB and the other is a '94 Vert. I ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-30-08, 02:11 PM
I have two cars with Tweecers. One is a TT '65 FB and the other is a '94 Vert. I want to share what worked for my Vert. Hopefully, it will work on my TT as well as it does this worse than the Vert.
The symtom was bucking/surging just off idle under slight accel or decel conditions. Typical example would be slowing for a stop. If I left the car in 3rd and coasted to the stop, at about 1200 RPM the car would begin bucking. At 1100 it would be really bad. Another example would be idleing along in a freeway jam up. If I left the car in 2nd and coasted at idle, sometimes it would buck. Almost always, it would buck just slightly past the idle stop if I wanted to speed up a bit.
Anyway, I tried to fix this problem for a year. KMRFs are good, low RPM timing was reduced. Repeated data logging didn't show the problem. Out of desperation, I tried changing the dashpot prepostion function. I was under the idea that this was ISC duty cycle vs RPM. The vaules I had there were not to far off from the Cobra tune. I reduced the velues by 15% and give it a try. It worked!
I hope to try this on my TT soon. I will let yu know if it worked.
Eric
  #2 (permalink)
Old 09-30-08, 07:18 PM
Mustangless's Avatar
Official Member
My problem does not sound as bad as yours, but I do have that problem. My kams are good, and my spark is stock in those areas. I might have to try to change that.
  #3 (permalink)
Old 10-02-08, 05:46 PM
final5-0's Avatar
Official Member
Good for you
That is one nice thing about having pcm access
You can try things out
If your idea don't pan out ... You just put original values back
Grady
  #4 (permalink)
Old 10-02-08, 07:05 PM
Hey Grady!
Lets hope it works on the TT. I will give it a shot soon.
Eric
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
