Quote:
Originally Posted by Kryptonite92 The car sleepy mentioned above is actually mine, we are all pulling our hair out trying to figure out what the problem is. the firing order of the cam is 13726548, the tps sensor is brand new i checked both the orange wire and the green wire both have 5 volts which i know cant be rite, im gonna have the codes pulled asap. would the o2 sensors cause this? another question is, is there any difference in the computer harness from 92 to 93? the harness and comp came off a 93 gt. also runs like crap when cold after warm up its ok but after about 2-3 min of idleing the rpms instantly drop and it struggles to idle, i can shut it off and start it and it runs fine for 2-3 min then the same thing happens. My car is in excellent condition which is rare around here which is why i dont want to put a carb on it so any help is greatly apreciated. |
Try to dump the codes. My bet is you won't be able to get them to dump.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
The STI has a gray connector shell and a white/red wire. It comes from the same bundle of wires as the self test connector. There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer. What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
For those who are intimidated by all the wires & connections, see
Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see
EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
