Mustang Forums at StangNet
A/F Tuning Q + ProM 80mm 24lb datasheet?
This is a discussion on A/F Tuning Q + ProM 80mm 24lb datasheet? within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; I have a quick issue when tuning. It seems anytime I step on the gas, WOT, the car goes extremely ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-11-08, 10:05 AM
Official Member
I have a quick issue when tuning. It seems anytime I step on the gas, WOT, the car goes extremely rich 8.0:1. Is this because of the MAF or because of something else. I had it tuned well last year but now I am having trouble getting it to stay around 12-13:1 at WOT. My idle is fine at around 14:1.
Also does anyone have a Prom or PMAS 80mm 24LB datasheet? I cannot find mine. Also I've been using just the Prom24 from the tweecer files, is that a good replacement?
  #2 (permalink)
Old 10-12-08, 09:09 AM
2002BLGT's Avatar
Official Member
was it running fine and just change on its own , or did you change something ?
  #3 (permalink)
Old 10-12-08, 11:20 AM
final5-0's Avatar
Official Member
Sounds like something has gone wrong
You say it was tuned fine last year
Usually one gets his Closed Loop tune fairly close
then
He goes to work on the Open Loop or WOT tune
Not doing it in that order just makes for double work
cause your inj values effect the Open Loop tune you
just got done with when you get around to tuning
for Closed Loop
Briefly ... the fuel tables in our pcm's call for high 11's to 1
In a nutshell ... For WOT fuel tuning
I work with the Open Loop only part of the maf curve
I set my fuel table a bit fat all across the rpm range
I then adjust the maf curve to achieve the commanded ratio seen
on my wb from the table
That allows me to easily change my ratio with fuel table values
Since you are seeing 8.00 to 1.00
Something ... Somewhere ... has got to have gone wrong
for you to be seeing that fat of a mixture
or
Your wb is outta whack
Grady
  #4 (permalink)
Old 10-12-08, 07:57 PM
Official Member
So I looked through all my data and apparently the ProM24 included with the tweecer is not correct? I got the PMAS 24 cal sheet and the results were much better.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
