I just picked up a used Paxton 1220 SL for a good price. It has the fmu with it from the kit which I'm assuming is a 12:1 set-up. I have 30lb injectors that I want to use and only a 155lph pump. Can I use the fmu if I recalibrate it to 4:1 or the proper ratio? Should I use a t-rex pump or should I just get a bigger 255lph pump?
I know ultimately I will need to get a tune or run a pms of somesort. (sold my tweecer).
Any suggestions?
