Mustang Forums at StangNet
Can you name these things for me
This is a discussion on Can you name these things for me within the 4.6 Tech forums, part of the 4.6L Mustang category; Can you tell me what these things are, what their sources and destinations are and what their primary functions are. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-08-08, 11:30 AM
Can you tell me what these things are, what their sources and destinations are and what their primary functions are. Most importantly I want to know what the ones going into the intake and coming out of the intake plenum are, but if you could answer all of them, it would be great.
Picture 1
Picture 2
Picture 3
Picture 4
  #2 (permalink)
Old 11-08-08, 12:13 PM
Shiroelex's Avatar
There's nothing worse than automotive blue balls.
Ok, the first pic is a a picture of one of the A/C lines. I forget what that bubble in the line is called specifically, though.
Second picture is your fuel pressure regulator.
Third picture: Left item is the Idle Air Control valve, and the plastic box in the tube is a muffler of sorts to stop wind noise and hum from it. The right item is your EGR valve.
Fourth picture on the left is a breather tube that should connect to the intake tube itself. You can throw a breather filter on that and plug the intake tube hole, but some drag strips don't like that. The right item is a vibration dampener on the brake booster, but I could be wrong on that.
I also noticed that this is an automatic, with a system.
  #3 (permalink)
Old 11-08-08, 08:58 PM
GoldMember
dankush:
2nd picture is a fuel pressure damper. The regulator is at the end of the fuel rail (pre-99) or on the middle of the rail on the passenger side (99 and newer).
4th picture: the black tube is part of the positive crankcase ventilation (PCV) system. The PCV valve is on the other cover and, as "Shiroelex" said, the smelly gases vent to the intake tube rather than the atmosphere. If you put a vent/breather on the cam covers you can bring in unmetered air into the engine and this can cause a lean condition. Unless you are running a supercharger, I suggest that you leave the PCV system alone.
Pick up a Haynes manual ($20) at AutoZone or Borders or your local bookstore. It has lots of pics and very good instructions, imo. If you are flush with cash, pick up a Helms shop manual ($100 to $150 for the paper version).
HTH,
Chris
  #4 (permalink)
Old 11-08-08, 09:16 PM
twogts4us's Avatar
Official Member
Garage
Quote:
Originally Posted by nyuk98gt View Post
dankush:
Actually, it's a fuel pressure sensor. This is a returnless fuel system. The pressure is 'regulated' at the pump.
  #5 (permalink)
Old 11-08-08, 10:13 PM
GoldMember
twogts4us:
Not to be argumentative but.... Doesn't a sensor need to send info back to the PCM (or an intermediate receiver)? There are no wires coming off that disk-shaped device. I have the same thing [damper!!] on my '98 (I think we all do) in addition to a vacuum-controlled regulator on the end of the fuel rail. I understand that the returnless system pump works on variable voltage and there is no need for a "pressure regulator" but there is a fuel rail pressure sensor (FRPS) on one fuel rail and it goes bad from time to time causing problems for you +99 owners. The PCM uses the FRPS to regulate the fuel pump. If the rail pressure is lower than it should be for a given RPM/load then the pump is sped up, if the rail pressure is higher than it should be for a given RPM/load then the pump is slowed down. Any spikes in the pressure are moderated by the little damper.
No offence intended.
Chris
  #6 (permalink)
Old 11-09-08, 03:30 PM
blackink00's Avatar
I missed a shift & stole Curt's money.
it is a dampner. the ruel rail pressure sender is on the fuel rail. pic 4 on the right side is a high pressure resivour for power assist brakes. the ac line has a muffler on it and that would be the high pressure side.
  #7 (permalink)
Old 11-09-08, 05:58 PM
twogts4us's Avatar
Official Member
twogts4us:
Chris
Sorry Chris, let me clarify...the comment I made ("Actually, it's a fuel pressure sensor") was referring to was your statement:
We're on the same page, I just didn't make it clear which item/comment I was referring to (damper vs. FPS).
Thanks!
Chris (yeah, I'm Chris too )
  #8 (permalink)
Old 11-09-08, 06:42 PM
GoldMember
twogts4us:
Two Chris's -- dankush has got his "Chris mojo" workin'!!
Thanks for the clarification, we are on the same page.
Chris II
  #9 (permalink)
Old 11-09-08, 07:44 PM
fast97gt's Avatar
Official Member
Quote:
also to add, cars pre 99' have this also and they utalize the return system.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
