Mustang Forums at StangNet
Twisted Wedge from Trick Flow
This is a discussion on Twisted Wedge from Trick Flow within the 5.0 Tech forums, part of the 5.0 Mustang category; What does everyone think about this kit?? My car is a 92 gt and i just want a respectable street ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 153,000 Members!!
Reply
  #1 (permalink)
Old 11-09-08, 08:42 PM
snakebite01's Avatar
Official Member
My car is a 92 gt and i just want a respectable street car.. I was thinking about this twisted wedge kit from trick flow Trick Flow Specialties TFS-K514-360350B - Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L - summitracing.com
does it seem like a good kit to go with for the price and what i would be getting out of it??
if so what crank and pistons should i get to go with this set up??
and does anyone know what lifters i would need???
- Matt
  #2 (permalink)
Old 11-09-08, 08:53 PM
StangGT1995's Avatar
have car, will race....wait, it doesn't run
It's a great kit. You could use it with the stock internals, or step up to a stoker kit if you were looking for more power. On a stock engine, most people are in the 300-315ish RWHP range after bolting it on.
  #3 (permalink)
Old 11-09-08, 10:41 PM
Brian@PAR's Avatar
Official Member
That kit is a great deal as long as you're not expecting to grow too much. The biggest part of the kit are the heads and at 170cc's they are pretty much maxed out on a 302 IMO. Even though a TW 170cc head is "bigger" than a standard in-line 170 you're still only looking at a bit over 400 HP N/A capability.
I would recommend the COMP 851-16 lifters. If you are budget minded the FMS lifters will do fine but you're best off to replace them if you change the cam and up the spring pressure.
Also if you go with this kit don't just drop it in and assume all is good. Even though it comes as a "matched" set you still need to degree the cam and check valve train geometry.
  #4 (permalink)
Old 11-10-08, 08:54 AM
Official Member
yeah, i'm very tedious when it comes to my motor. i will still check all my clearences and geometry...
  #5 (permalink)
Old 11-10-08, 08:55 AM
Official Member
Quote:
if i wanted to stroke it out what pistons should i go with along with this kit??
  #6 (permalink)
Old 11-10-08, 09:15 AM
dcurtis's Avatar
Official Member
probe srs pistons ftw
  #7 (permalink)
Old 11-11-08, 10:15 PM
Official Member
Quote:
what about this kit, eagle pistons rods and forged crankshaft + boost??
  #8 (permalink)
Old 11-12-08, 07:07 AM
millhouse's Avatar
Quote:
If you plan on throwing boost at it, you may want to re-think your setup and skip the new rotating assembly. The stock bottom end will be more than adequate for block splitting horsepower, and adding a built rotating assembly to is not only not necessary….but also can be wastefull if/when the block splits and takes out all of those expensive goodies.
So if you’re looking to add boost, the h/c/I, stock shortblock and 10lbs should get you into the 500rwhp range.
  #9 (permalink)
Old 11-12-08, 11:09 AM
Official Member
i see you know about boost.. what h/c/i would you suggest?? i wanna do a tt setup
  #10 (permalink)
Old 11-12-08, 03:18 PM
millhouse's Avatar
It's hard to beat the tfs top end kit. They have been proven time and again to produce great numbers. I'd prefer the f303 over what comes with the tfs top end kit, but it will do just fine.
  #11 (permalink)
Old 11-12-08, 08:27 PM
ShortThrow50's Avatar
Official Member
its a great kit. heres videoof my car right after i installed it on my car when i had stock 302 short block
YouTube - My 93 LX right after my trickflow H/C/I and Tko 600 install
  #12 (permalink)
Old 11-12-08, 11:07 PM
Official Member
that seems nice... thanks for the vid
  #13 (permalink)
Old 11-12-08, 11:08 PM
Official Member
great.. i'm thinking that's the kit i will put on.. and if i have the money i will get eagle pistons, rods, and crank, and a bottom block!!!
  #14 (permalink)
Old 11-13-08, 12:58 AM
ID89GT's Avatar
Official Member
Wow you have a lot of cars :O
  #15 (permalink)
Old 11-13-08, 06:35 AM
millhouse's Avatar
Just be sure to not pot that rotating assembly in a stock block if you are for sure going to run any type of forced induction! If you don’t have the cash for everything, I’d suggest throwing the h/c/I on the stock block along with the turbo kit…..and building a stout bottom end while you have the funds. Once you have the bottom end ready to go, swap the h/c/I into you’re new block and crank up the boost!
  #16 (permalink)
Old 11-13-08, 10:39 AM
Official Member
Quote:
lol i try
  #17 (permalink)
Old 11-13-08, 10:41 AM
Official Member
yeah,, i'm hoping to have all the money to get it all done at once so i don't have to do twice the amount of work..
  #18 (permalink)
Old 11-13-08, 02:50 PM
Official Member
no problem
  #19 (permalink)
Old 11-13-08, 04:36 PM
Official Member
no problem
where did you have that camera mounted??
  #20 (permalink)
Old 11-13-08, 05:51 PM
Official Member
LOL. I should take a pic next time when i film my 347 stroker setup. I use painters tape and tape it in between the 2 back seat back rests. You would laugh if you saw what i did, but hey it works
  #21 (permalink)
Old 11-13-08, 11:58 PM
Official Member
haha it worked great,, i didn't see any flaws in the video.. i gotta try it.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
