Mustang Forums at StangNet
car troubles, HELP please
This is a discussion on car troubles, HELP please within the Other Auto Tech forums, part of the General Automotive Forums category; I was driving me Daily Driver when it shut down on me in the middle of the road. I thought ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-14-08, 03:20 AM
sarges_heroes20's Avatar
I was driving me Daily Driver when it shut down on me in the middle of the road. I thought I heard metal scratching like when your all ready started and you turn over the key again (grinding) but im not shure.
I checked an put gas in the stupid thing, its got gas. I can hear the tank pump running when key is turned to "on" and the whole thing lights up about as bright as usual.
Oil was changed reg. since I took it over at 90k miles (its about 160k miles now have to go look for an exact reading) and the antifreeze is in there full and is good still I think.
The tow guy said it might have been the pump shutting off, I said I can hear it turning on but he checked any way. its running up.
Bout the only thing the dash board "idiot lights" are doing is there normal start up routine and then the battery light stays on.
It cranks up smooth and sounds like always, save no growl to life.
It just wont start, whats wrong with it??
It is a FWD 4 banger, manual 5-speed escort. and i has work tomarow.
  #2 (permalink)
Old 11-14-08, 04:12 AM
Was just out at the car, trying to get it to start and here is what happened.
I looked for the fuel pump auto cut of switch. it was pressed all the way down. so I used a philips head screw driver to pop it up. it came up from just setting the screw driver in there. I thought for shure that was it (but pissed it would cost me a $77 dollar tow though) I tried to crank er up. wouldnt go. but pump was running both times, figure that out!
Now I have found out me manual is gone. im freaking out here!!!
  #3 (permalink)
Old 11-14-08, 04:25 AM
What the H*** is wrong with this thing!! where is my manual?? *freaks out*
*cant afford another car*
  #4 (permalink)
Old 11-14-08, 05:46 AM
sphinx's Avatar
Did you get it running?
  #5 (permalink)
Old 11-14-08, 06:01 AM
Quote:
no I have not. I have pulled the timing belt hood thingy (easy 3 screws, then pull of) and the belt is on there and I think intact. its a really cracked all over but none appear to go all the way through it (not to self save up some dough cus thats gona need attention soon)
Is the fuel pump cut off switch (little yellow piece of junk in trunk) suppose to be down or up? I have lost my manual & the little sticker on it says consult that when it only need say "its suppose to be (up or down which ever it is) and use some a screw driver to pop it up" all its got to say, could use 2 little pictures but no its got to redirect me to a book i dont have. grrrr. <--to ford, stupids!!
By the way mine is down, tried it up still didn't work. whats it suppose to be??
  #6 (permalink)
Old 11-14-08, 06:17 AM
sphinx's Avatar
CAREFULLY check the shrader vavle on the fuel rail and see if you have fuel pressure. If you do then check to see if you have spark. I have to get my 3 year old ready and to daycare then I'll be back and can pull up the info you need on Mitchell.
  #7 (permalink)
Old 11-14-08, 06:35 AM
ok, I will check that. Ford Timing Belts & Chains
If that site is accurate then the 99 zx2's DOHC 2.0 motor needs replacement of the timing belt every 120k miles. Im at 130,332 miles. Im in trouble aren't I??
  #8 (permalink)
Old 11-14-08, 06:42 AM
If it is the timing belt wouldn't it be loose and fall away from the cams when I pulled the cover back?? This one was tight to the cams but loose in between them.
  #9 (permalink)
Old 11-14-08, 06:48 AM
sphinx's Avatar
Might have jumped a tooth instead of breaking is it loose on both sides?
  #10 (permalink)
Old 11-14-08, 06:51 AM
its wiggle able in the middle, were dealing with a DOHC motor. I cant reach down to the sides, its protected by a metal shield on one side and to much junk on the other.
Ohhh god dont let it be that damned belt!!
  #11 (permalink)
Old 11-14-08, 06:53 AM
sphinx's Avatar
Yeah you might be in trouble.
CAUTION: This application is an interference engine. Do not rotate camshaft or crankshaft when timing belt is removed, or engine damage may occur.
Thats the first line in On-Demand. Now is it a vin code 3 or a vin code P?
  #12 (permalink)
Old 11-14-08, 06:55 AM
I broke a belt on a 95 escort once. completly ruined an other wise good car. That belt was like 2 sizes to big and could be pulled out quite far. This one is just a little give in the middle, still tight on the actual "gear" looking things on the cams.
I read some thing about running out of gas and having to pull the + lead off the battery for about 5 min. then try it again and things work for people. Im going to go try that.
  #13 (permalink)
Old 11-14-08, 06:56 AM
sphinx's Avatar
Now that you're awake .... 120k is just the recommended interval, it's not written in stone. If it's not broken you are probably ok and it's something else. Do you have fuel pressure? do you have spark?
  #14 (permalink)
I have no idea on the VIN code thing there. I know its a 99 zx2 with a 2.0 DOHC motor in it.
  #15 (permalink)
Old 11-14-08, 06:58 AM
sphinx's Avatar
it should be a vin code 3, code P says sohc
  #16 (permalink)
Old 11-14-08, 07:00 AM
I don't have any thing to pull the spark plugs with. I have some wrenches, screw drivers and a simple house hold socket set (wally world "dad christmas tool set" type) thats what im workin with.
Im headed out to check that fuel press. right now. Damn I been up all night because of this.
  #17 (permalink)
Old 11-14-08, 07:19 AM
ok, There is fuel spitting out of the shrader valve. there is pressure there. I tried the 5 min. thingy to, no luck.
Wish I had some one to stand there an watch the timing belt. that would put that fear to rest for good.
P.S. Vin code 3 is that good or bad?
  #18 (permalink)
Old 11-14-08, 07:34 AM
FYI that SOHC is peice of bull crap! any damned thing snaps on it every thing goes an brakes. like a dominoes thing. and the cars are so cheap even a timing belt change could add up to half the cars total worth.
  #19 (permalink)
Old 11-14-08, 07:35 AM
sphinx's Avatar
just means you have a dohc instaed of sohc. or instaed of 95 hp you have 110.....
lick your finger and then wipe it on the timing belt, then get in and turn the car over.....see if the wet spot moves
  #20 (permalink)
Old 11-14-08, 07:48 AM
MustangLX-5.0's Avatar
So this is an Escort ZX2 ? They used the same 2.0 on the Focus also.
It's cranking but not turning over...correct? What was that noise you were talking about? Said it sounds like starter gear grinding or something.
Is there anything else unusual you notice while turning ignition? Also,as a rule out test,pull a plug wire + plug.Turn over with plug in wire..out of engine.Ground side of plug to block.check to see if you got spark.
  #21 (permalink)
Old 11-14-08, 07:55 AM
So twice as many things to go wrong with it.
Okay, I had to use a wet towel but end result was the same. it started drizzeling here during the test (still is) and I am pretty shure it moved. wet spot was gone.
now I am going to get some sleep. Thank you for your help.
  #22 (permalink)
Old 11-14-08, 07:57 AM
sphinx's Avatar
I figured it would have COP.....Mitchell says "distributorless" so I guess not.. if you can't get a plug out I've used a bolt shoved into the boot and just set it so that it was about an 1/8 inch away from the engine. The noise throws me too..... almost makes me think the timing belt did jump teeth......
  #23 (permalink)
Old 11-14-08, 08:01 AM
Yes this is the escort ZX2 w/ 2.0 DOHC motor. Don't know about focus, really hope I never get into one of those things.
The starter motor will turn the engine over, Fuel spits out of the shrader valve, and can't check the spark plugs. my socket set does not have deep wells and they are way down there. I have tried before this time to get them out, deep well sockets are the only way it can be done.
While turning ignition on every thing sounds and acts the same as its usual start up routine. These engines shake a bit when turning over and make a real ruckus. all of that is same, just no coming to life after a sec. or 2.
  #24 (permalink)
Old 11-14-08, 08:08 AM
Ohh, there was a plastic box on the + post of battery which was broke many years ago. just + power leads to varouse things the car cant seem to run with out. I have them mashed down by those cheap replacement battery posts u get at auto parts stores. Has worked for years just fine save it gets that build up on em some thing bad.
I keep a battery post cleener and some wrenches with the car just to clean that, and have done it. didn't do much but wake up the electrical systems some, not nearly bad enough to cause the problem.
I don't have a clue what the heck is wrong with this peice of junk.
  #25 (permalink)
Old 11-14-08, 08:25 AM
sphinx's Avatar
Check your PM
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
