Mustang Forums at StangNet
Bronco brakes
This is a discussion on Bronco brakes within the Other Auto Tech forums, part of the General Automotive Forums category; Hey everyone, I have tried almost everything to figure this out except buy a chiltons manual. I have a 92 ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-14-08, 04:38 PM
Official Member
Bronco brakes
Hey everyone, I have tried almost everything to figure this out except buy a chiltons manual. I have a 92 ford bronco that I recently got back to working condition THANKS TO YOU GUYS. now my front brakes are grinding. I figured no problem I can replace them. took the wheels off and was like how the heck do you get these things off. my bronco has auto locking hubs I see the cap on the end of it that has 5 or 6 screws. I took that off thinking it would free up the hub to move off but it didn't so how do I go about getting the hub off so I can get the rotors off. someone told me it might be a complete unit. From looking at it, it does kind of look like it's a complete unit. Has anyone on here done this before.
Thanks
Ford Kid
  #2 (permalink)
Old 11-14-08, 04:40 PM
hotcobra03's Avatar
Premier Member
Posted via Mobile Device
  #3 (permalink)
Old 11-14-08, 04:48 PM
hotcobra03's Avatar
Premier Member
2 clips 1 on axle shaft round snap ring with 2holes or could be 3/4 round and flat than the 2nd is tiny and is locks on hub.you need 2 screwdrivers you need to pick at it to get it to pop than try to get behind it to pry out
  #4 (permalink)
Old 11-17-08, 03:21 PM
Official Member
Hey thanks, I found the retaining spring that was on the shaft it self. I had to push back the spring to get to it. once that came off the spring it self came off. then I found the other one behind that one that I needed two screw drivers for. then the peice of metal that, that spring was holding in slide out off of the shaft, but the whole rotor hub assembly won't move, there is still some kind of spring inside that I have no idea how to get it out or if I need to get it out. I hope I am making sence.
Thanks
Ford Kid
  #5 (permalink)
Old 12-01-08, 03:35 PM
hotcobra03's Avatar
Premier Member
You took out tiny screw clip is like 6inch round
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
