Mustang Forums at StangNet
Power Lumbar Wiring Harness
This is a discussion on Power Lumbar Wiring Harness within the V6 Talk forums, part of the 94-04 V6 Mustang category; Can anyone tell me where the unused connectors connect to? I do know the small one goes to the rocker ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-22-08, 11:08 AM
drdino's Avatar
Can anyone tell me where the unused connectors connect to? I do know the small one goes to the rocker switch for the power lumbar support. I do not know where the other two connectors connect.
Thanks
  #2 (permalink)
Old 11-22-08, 12:22 PM
hotcobra03's Avatar
Premier Member
Is it with power seat?
  #3 (permalink)
Old 11-22-08, 05:52 PM
drdino's Avatar
Yes. The original seat had a track supporting 6 way power seat w/o power lumbar support (2003). I replaced the seat with one with 6 way power seat and power lumbar support. I was told that I needed the harness (attachment) to get the lumbar pump working. I replaced the seat only, not the track.
I have the harness but am not sure where to make the connections.
Thank you.
  #4 (permalink)
Old 11-22-08, 06:52 PM
hotcobra03's Avatar
Premier Member
So u had a power seat without lumbar.now you put a seat with lumbar.what year is your car and year 4 new seat.if i was to guess one would go to switch for lumbar and the other in pump motor 4 lumbar
  #5 (permalink)
Old 11-23-08, 09:52 AM
drdino's Avatar
My car is a 2003. The track is the same. The seat only was changed and it came from a 2001 GT. I see where the one end is connected to the pump. I also know where the rocker switch connector is. What I do not know is where the other two connectors connect. The connector close to the rocker switch connector and the connector at the other end.
Thank you for your help.
  #6 (permalink)
Old 11-23-08, 10:14 AM
hotcobra03's Avatar
Premier Member
What is the full number on blue tag.and what colors are wires im looking at fords diagram
  #7 (permalink)
Old 11-23-08, 10:37 AM
drdino's Avatar
The numbers on the Blue tag are: XR33 14B084. There is also a B129J After Made In Mexico.
The two connectors I don't know where to connect follow.
The wire colors on one connector are: Black, Yellow w/Green Stripe, Yellow w/White Stripe, Yellow w/Blue Stripe, Green, Red w/Blue Stripe, Red w/White Stripe, Red, Green.
The other connector has: Yellow w/Blue Stripe, Yellow w/Green Stripe, Red w/Blue Stripe, Yellow w/White Stripe, Black, Red w/White Stripe, Green, Red w/Green Stripe.
Thanks
  #8 (permalink)
Old 11-23-08, 11:17 AM
hotcobra03's Avatar
Premier Member
Ok c if harness number 14c719 is used with other seat? Seat adjustment switch
  #9 (permalink)
Old 11-23-08, 04:36 PM
hotcobra03's Avatar
Premier Member
Unplug other harness.. switch to motor
  #10 (permalink)
Old 11-25-08, 02:24 PM
drdino's Avatar
That did it!!!! Thank you very much!!!!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
