Mustang Forums at StangNet
overheating!!!!!
This is a discussion on overheating!!!!! within the V6 Talk forums, part of the 94-04 V6 Mustang category; just bought a 97 noticed it was running a little hot but not fully over heating turned the heat on ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-29-08, 06:55 PM
overheating!!!!!
just bought a 97 noticed it was running a little hot but not fully over heating turned the heat on and it went down to a little passed normal got home and popped the hood and noticed the fan was not kicking on. There was a recipt in the car for a fan that was bought 2 months ago so, i turned the ac on and the fan turned on is there a relay or something i am missing for the fan??? please any info would help thanks....
  #2 (permalink)
Old 11-30-08, 01:39 PM
MustangLX-5.0's Avatar
You did let the car idle for a little while waiting for the fan to kick in? It will only turn on when the temp gets to a certain point (around 213 degrees or so).If it does not turn on past this point yet it will turn on with the A/C engaged then your ECT (Engine Coolant Temp ) sensor is faulty.
Try this test.Start the car.Now under the hood,look behind the ignition coil pack.Theres 2 sensors back there.The ECT sensor is the one with 2 wires (NOT the one to the right with 1 wire,thats your temp gauge sender).With the engine running,unplug the 2 wire sensor.The fan should kick in a few seconds after unplugging it ...then shut off once plugged in.
Do you have an ohmmeter? Something you could use to check for resistance and voltage.
  #3 (permalink)
Old 12-08-08, 05:48 AM
klotzstang's Avatar
You could have a bad relay in the CCRM.
94-95 Mustangs Cooling System Diagnostics - Mustang-Tech
  #4 (permalink)
Old 12-09-08, 06:49 AM
klotzstang's Avatar
NOTE: Almost all Fords 1994-present, have a CCRM.
  #5 (permalink)
Old 12-10-08, 01:41 PM
Just FYI.The CCRM (Constant Control Relay Module) is located in the passenger side fenderwell.Remove the splash shield and the module is just off to the right.You cant miss the mass of wires coming out of it.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
