I will, alrite people I swapped u joints in my 97, it had no vibes at all, even 30*** miles after the gear swap. However when I did new u joints I got a vibration, I had put the ds on the pinion flange in the wrong location, turn it to the next set of holes and fixed it. Now I'm agreeing with the ds not spinning faster theory, it spins quicker through the rpm range but your ds is spinning the same speed once you hit top gear, now hold on ok, here's my theory, my 5th gear is like my 4th gear, so with me in 5th with my 4.10s is like doing 70mph in 4th with stock gears. So yes you can say its spinning faster but its not the same. So if had no vibes at 70 in 4th with stock gears you should have none now. When they had the ds off they could of not put it back in the right holes
Posted via Mobile Device
