Mustang Forums at StangNet
Any of you guys have Eibach Pro Kit struts installed? Need help please
This is a discussion on Any of you guys have Eibach Pro Kit struts installed? Need help please within the 2.3L Mustang Talk forums, part of the 2.3L Mustang category; I'm looking for some feedback here.Do any of you 2.3 stangers have Eibach Pro kit dampers installed on your stang? ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L Mustang Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 12-03-08, 05:27 PM
MustangLX-5.0's Avatar
I'm looking for some feedback here.Do any of you 2.3 stangers have Eibach Pro kit dampers installed on your stang? And if so ,did you use the factory upper strut mounts (on the strut tower) or an aftermarket Caster/Camber kit?
I used the factory mounts and the strut rod nut doesn't tighten down that far (no threads sticking up past the nut).I also used the factory spacer that fits in the bushing.I was told a year ago by a few of you at SN it would work with factory mounts.Well something doesn't work because the control arm drops down too far and I cant connect the sway bar end links to the bar itself.Not without tearing the bushings.
I've been trying to get this issue with my 92 5.0 resolved and nobody seems to know anything.It's been over a year and I still don't have an answer.I'd really appreciate some assistance.
Frustrated stanger wants to drive his 5.0.......
  #2 (permalink)
Old 12-04-08, 11:35 AM
Red_LX's Avatar
Doubt I could be of much help, unless you need porn pics!!
Location: Morgantown, WV...where couches meet their doom
What do you mean by "the control arm drops down too much?"
  #3 (permalink)
Old 12-05-08, 12:20 PM
When installing the struts,you have a floorjack holding the arm up untill you get the strut bolted in.Once that's done,I lower the jack to let the arm down.The struts allow it to drop a certain ammount untill it's locked in place by the strut rod end.
When the arm is lowered,I can't reach the sway bar end links to the sway bar itself.I have to lift the arm first.....this is my main problem.I can't do it this way without tearing the links or busting the sway mounts from it droppng too far.Both drivers and pass. sides do this.
I thought it was the wrong struts.I've confirmed 3 times that they are the correct ones.I even called up Eibach but there isn't anything they can do since everything matches.
So I don't know what the problem is.I'm just trying to get this figured out.
Thanks for the assist RedLX.
O/T..
Good to see your still hangin around the 2.3 forums after all these years.Btw,where's LsRedy2kstang? Is he even around nowadays?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
