Mustang Forums at StangNet
Taurus taking antifreeze........
This is a discussion on Taurus taking antifreeze........ within the Other Auto Tech forums, part of the General Automotive Forums category; Hi, my 02 taurus has the 3.0 vulcan i believe, and it has been taking a large amount of coolant ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 12-15-08, 10:03 PM
351vic's Avatar
Hi, my 02 taurus has the 3.0 vulcan i believe, and it has been taking a large amount of coolant lately, then the other day it developed a strange squeak near where the bellhousing meets the block right under an electrical raceway full of wires. If i push on the raceway, the squeak goes away, but there are no moving parts visible... Also it now started to idle kinda erratically and shut off on me a couple times, but the temp is always fine, and the check engine light isnt on so i cant pull any codes.... Anyone have an idea? Intake gasket? Thanks
  #2 (permalink)
Old 12-15-08, 11:22 PM
StangGT1995's Avatar
have car, will race....wait, it doesn't run
I'm not sure if the Taurus used the same 3.0 V6 as the Windstar did, but if so, it's probably a headgasket. Pretty common issue, should it be the same engine. Do a compression/leakdown test and see if you can find the source, as well as a pressure test of the cooling system, if you have the equipment available.
You may still have a code stored, even though the CEL isn't illuminated, so pulling them may still be a good idea. I'm not sure what to make of the squeaking coming from the wires, aside from having a look around for anything that's loose in that area. Possible loose bellhousing bolt, maybe?
  #3 (permalink)
Old 12-17-08, 07:52 PM
351vic's Avatar
Thanks, I did a leakdown test and it came out good, but i dont have the tools for a cooling system pressure test so I took it in today and had the shop look at it, and also had them scan it so we shall see
  #4 (permalink)
Old 02-05-09, 08:24 PM
Official Member
I know this thread is probably dead, but if you havn't gotten it fixed yet, sounds like you gotta bad cam sensor. By the squeeking noise you describe by wiring harness by the t-stat housing, and the driveability issues you are having. As far as the coolant usage; if you see coolant on the ground on the passanger side, you most likely have a front cover gasket issue. Also, if not fixed, i'd put a water pump on it too while you have it all apart, if you even have blades left on the water pump.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
