Mustang Forums at StangNet
E7 heads or 351 heads for 302 in F150
This is a discussion on E7 heads or 351 heads for 302 in F150 within the Other Auto Tech forums, part of the General Automotive Forums category; the short of it... I have a '87 94K mile F150 w/ 302 C-6 short bed std cab that I ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 12-16-08, 10:15 PM
Jason Burson's Avatar
the short of it...
I have a '87 94K mile F150 w/ 302 C-6 short bed std cab that I am building with my son. The truck is stock except for pullies and off road H-pipe and flowmasters and turn downs. I bought a couple of '86 parts trucks, one has EFI 302 AOD and the other is 351 C-6 w/ carb. digging through old parts, i also have a set of stock mustang shorty heads and E7 heads. The '87 has a C-6 so over the Christmas break we are planning to install the AOD from the '86. For Christmas I got him a cam (1500-4000 RPM 280/290 Adv. Duration .448/.472 lift 112 Lobe Center) and while at it I was thinking about installing the set of stock '89 mustang shorty headers.
My question is while in the engine should I consider installing a set of stock E7 heads, or maybe the 351 heads from the '86 351 truck, or perhaps have the set of E7 heads or the 351 heads reworked (slight port/polish, maybe bigger valves installed *if possible*) locally since we will be right there?
btw, this summer (sooner if needed for cam) I plan to convert the truck to SEFI and mass air.
  #2 (permalink)
Old 12-17-08, 12:29 AM
StangGT1995's Avatar
have car, will race....wait, it doesn't run
The E7 heads are probably better than the 351 heads on the 86, if they're not the same ones. The Mustang's E7 heads were taken from the parts bin, which just happened to be something Ford already had in its inventory and used in production, on other cars and trucks.
  #3 (permalink)
Old 12-17-08, 12:34 AM
Gearbanger 101's Avatar
SuperMod
Canadian Colossus
Correct...the '87-up E7TE heads were in fact F150 heads of the same year. The '86 heads might be a lot more restrictive if they're also the same ones from the Mustang of that same year, so I wouldn't chance it.
Also, keep in mind that the 351W heads will have 1/2 head bolts, so you'll either need to sleve the head for the smaller 7/16 bolts, or drill and tap the block for the larger ones.
Either way...the 351W heads of the 80's held no advantage over the 302W heads. Valve size is the same, as are the intake and exhaust ports.
If you want to work them over, that's fine...but for what it might cost, you'll probably be further ahead just buying a used set of aftermarket aluminum heads and calling it a day.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
