Quote:
Originally Posted by STANGDUDE76 Did the same on my 76 Cobra ll. lam useing the 67 Shelby Dynamite Sticks. The only problem is l keep burning out the trailer switch relay. Must find a H D relay or something. Anybody have any ideas? |
Before making a recommendation it would be good to know what relay is already in use and what it's driving/ the load.
Just took a look, pics a link:
I see, I'm guessing you ran a hot wire to the rear and are using relays patched into the factory loom?
Which part of the relay are you toasting, the contacts or the coil? And you would really want a diode on the coil to keep back feed voltage spikes out of the $300 Sticks.
Off the top of my head , if the relays your burning are those cutsie little things found on circuit boards you could step up to a horn relay, if your toasting a horn relay Bosch makes a nifty little 50 amp unit. Can't really day for sure since I don;t know the particulars of the wiring.
Depending what the needs are I suppose you could go to a junk yard and snag relays from just about any EFI car, relay brackets/ carriers and all.
Just an idea,
