Mustang Forums at StangNet
wide ratio with 3.73
This is a discussion on wide ratio with 3.73 within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; hey guys I need a little advice I'm planning on rebuilding my AODE again cause I got a crap job ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 01-14-09, 10:22 PM
gearhead302's Avatar
hey guys I need a little advice I'm planning on rebuilding my AODE again cause I got a crap job last time. gonna spring for a new valve body and ratchet type sprags. clutches and such. I'm considering the wide ratio set as well but I've heard people say that it may kill my time and lord I don't have any to lose. of corse I put in 3.73's a little over a year ago gotta a 3000 stall. somebody help I'm ready to get this thing goin
  #2 (permalink)
Old 01-14-09, 10:52 PM
Chythar's Avatar
Official Member
You'll need to get a chip to re-tune the transmission for the gears and the wide ratio gears. My GT has the wide ratio gears and 3.73's, and I was always bouncing off the rev limiter in 1st. I just bought a Moates chip and altered the tranny program some, and it shifts much better. Still needs a lot of tuning though.
  #3 (permalink)
Old 01-15-09, 08:15 AM
I've done some research and saw that people were saying that with a 3.73 the car would hit third in the quater and fall on it's face. but I was wonering since the car was so heavy would the difference be noticable at all. also I keep chewing up speedo gears. does anybody know what I need to change to keep this from happening. I know the driven gear needs to be changed but I think it is part of the shaft??? if so what do i need to buy??
  #4 (permalink)
Old 01-16-09, 07:57 AM
Stanger007's Avatar
Figure out based on your track tire size and gearing what RPM you want to cross at. There are several online calculators to help ya figure this out. You probably want to be crossing in 3rd around 5,800-6,000 rpm.
Off the cuff without knowing the ins and outs of your combo I think you will be fine with 3.73s on the spray and a 26inch-ish tire.
Wes
P.S. Lock that converter after each WOT shift!
  #5 (permalink)
Old 01-16-09, 11:09 AM
thanks guys. think I'm gonna go with it. and see what happens. it can't get much worse. guess I'm gonna get ratchet type sprags and good clutches and hope for the best
  #6 (permalink)
Old 01-25-09, 08:16 PM
KamiKaziDK's Avatar
Official Member
Just out of curiosity, have you dyno'd your current setup?
  #7 (permalink)
Old 01-30-09, 02:48 PM
Quote:
yeah I have, chris tutten did the tuning for me. I can't remember the numbers but I'm thinking it was like 278 rwhp off the spray
  #8 (permalink)
Old 03-21-09, 03:21 PM
just got it back and it's a different car. not sluggish out of the hole at all anymore. good pick up. can't wait to get it tuned and see what the difference is at the track
  #9 (permalink)
Old 03-21-09, 06:55 PM
toyman's Avatar
Official Member
Quote:
Quote:
PM me. I've got an electronic speedo recalibrator that I'll sell cheap.
  #10 (permalink)
Old 04-12-09, 10:08 PM
ok guys got a whole new set of problems. went to have the car tuned and driveability is 110% better. also the converter locks up perfect and shifts are firm and crisp. cant seem to make a pull on the dyno though. it wants to down shift let go or unlock at about 4500rpm at WOT. even locking it in 3rd by chip raising shift point and lowering down shift point does no good it still does it. bear in mind that the I have the wrong shaft to correctly drive the white spedo gear. could this be a problem??? the speedo is still off about 7-10 mph. I'm beating my head into the wall trying to figure this out myself. or could I need a bigger servo. any advice/ideas would be a great help.
  #11 (permalink)
Old 04-12-09, 10:09 PM
Stanger007's Avatar
I've got a template that will keep it locked on the dyno:
Automatic Dyno Settings - [tunexchange: Proudly burning chips and rubber since 2008]
Wes
  #12 (permalink)
Old 04-13-09, 09:57 PM
Wes
alright tried it still no dice. now I'm down to going back into the tranny I guess???
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
