Mustang Forums at StangNet
Fuel pressure recommendations
This is a discussion on Fuel pressure recommendations within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; I have a 95 GT with a vortech V-1 supercharger with forged flat top SPR pistons, AFR heads, gt-40 extreme ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 01-29-09, 04:45 PM
I have a 95 GT with a vortech V-1 supercharger with forged flat top SPR pistons, AFR heads, gt-40 extreme cam, gt-40 intake, Motorvation chip, 70cc TB, MDS ignition which retards the timing one degree for every pound of boost. I have an adjustable fuel pressure regulator with a gauge so I can put it to whatever I want. It was set at 53 with the vacuum off and it hunted to idle really bad, 53 sounded rather high so I dropped it down to 43. The idle cleaned immediately after and a week later I blew the motor running down the highway at 2500 RPM. I am having it rebuild but now want to make sure I have a good pressure. I don't know if the pressure caused it because of detonation or it was just a coincidence. I need help I don't want to blow another one.
  #2 (permalink)
Old 01-29-09, 05:15 PM
2002BLGT's Avatar
Official Member
Quote:
was the chip programmed for the supercharger ? and what MAF and injectors are you running and does the car have an FMU on it ? did you get the air/fuel checked with a wideband ?
  #3 (permalink)
Old 01-29-09, 09:22 PM
Yes the chip was programmed for the supercharger, I have 36 pound injectors, I would have to double check on the MAF and I dont think it has an FMU, if thats what I think it is. No It wasnt checked with a wideband.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
