Mustang Forums at StangNet
Wheel well factory coating?
This is a discussion on Wheel well factory coating? within the MII Discussion forums, part of the Mustang II category; After I finally removed all of the aftermarket undercoating on my '78 Ghia, I found a layer of blue-green textured ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 02-09-09, 05:49 PM
78CobraII's Avatar
Moderator
Garage
After I finally removed all of the aftermarket undercoating on my '78 Ghia, I found a layer of blue-green textured coating about 1/8" thick. Does anyone know what this stuff is? Specifically, is it a plastic, urethane, etc?
Also, its cracked in places revealing sheetmetal underneath and some rust. Is there a comparable product I could use to replace it?
Thanks.
  #2 (permalink)
Old 02-11-09, 04:05 PM
Take care of the rust area then coat the area with some type of rust preventive (por 15, rust bullet) then treat the area with the spray on bed liner material. If you don't want to use the bed liner you can always use the regular undercoating. What ever way you go, take care of the rust.
  #3 (permalink)
Old 02-12-09, 09:49 AM
78CobraII's Avatar
Moderator
Garage
Quote:
I guess I'll pick up a can of Eastwood's "Rubberized Undercating" to test. It doesn't sound much like what I'm seeing from the factory, but it's all I've seen so far.
I really like the idea of the 2-part bedliner, but I don't really plan to completely strip the wheel wells. I don't think that bedliner would work well in situations where you are spot-treating the area.
After years of laying under this Ghia scraping undercoating, sanding rust, applying rust converter, priming, and painting, my Cobra is going up on a rotissery and is going to be sandblasted, primed and painted all in one week! Then I'll coat the wheel wells with bedliner.
  #4 (permalink)
Old 02-12-09, 10:17 AM
78CobraII's Avatar
Moderator
Garage
3M has a great website where you can search for products. A search for undercoatings turned up "Paintable Ruberized Undercoating":
Dyna-Pro(R) Paintable Rubberized Undercoating
  #5 (permalink)
Old 02-12-09, 08:50 PM
Wart's Avatar
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
Quote:
Whatever it is, it's from Hell.
A torch is about the only way I can figure to remove it.
It will come right off the rust.
I would use the 2 part bed liner material.
{edit} I think sand blasting is pretty ineffective against that coating from Hell.{/edit}
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
