Mustang Forums at StangNet
5.0 engine/drivetrain/electronics for sale
This is a discussion on 5.0 engine/drivetrain/electronics for sale within the SE Classifieds forums, part of the Southeast category; Since I have a mod motor sitting there waiting for the GT, I have no use for my pushrod setup ...
Go Back   Mustang Forums at StangNet > Regional Forums > Southeast > SE Classifieds
Over 151,000 Members!!
  #1 (permalink)
Old 02-16-09, 08:40 PM
Since I have a mod motor sitting there waiting for the GT, I have no use for my pushrod setup anymore. Short of driving around the block now and then, I dont drive my GT anymore so I might as well yank the pushrod setup out and get some money for it. This will make an awesome setup for a street rod, or 4cyl car that someone has laying around. This has been a dead reliable setup with very few miles on it since the H/C/I change. Here is the rundown:
Stock Bore 91 shortblock, re-ringed and bearing'd roughly 10K miles ago. (still had crosshatching) 40PSI plus@idle when warm.
Cloyes Double roller chain
FRPP Hardened oil pump shaft
C&L 75mm Mass air meter with aluminum intake tract
70mm BBK/Edelbrock Throttle Body
Cobra Intake
Trick Flow Track Heat heads
ARP head studs
Stud-mounted 1.72 Skorpion roller rockers
Trick Flow hardened pushrods
Crane Roller Lifters
Trick Flow Stage 1 cam (221 /225 duration@0.50 236/248 lift with the rockers)
FRPP 24lb injectors
MSD 6-AL ignition
Crane Fireball Coil
FRPP HD clutch
T-5 5speed transmission with D&D Motorsports 2.95 billet 1st gear conversion gearset. (strong and quiet, third gear had just BARELY started gridning on fast engagement. I could throw a syncro in it when I yank it out or you can do it yourself. Its EASY.)
Hurst Shifter with Kirban "shorty" upper
FRPP aluminum Driveshaft
A9M ECU
Stock wiring harness (its an 86 GT so its up to you if you want it. I have no use for it)
Like I said this is a dead reliable/non smoking combination that I drove daily until I couldnt stand not having A/C anymore. My only regret is I never got to tune it as I am SURE there is more power locked away in it. Some guys on the board know the car. It's not a slouch of a combo but is still very driveable. I would rather someone get some use out of it instead of it just sitting here. NOTE: I would much rather sell the entire setup to someone instead of parting it out. Please don't PM me trying to get me to sell it in pieces. I would possibly seperate the tranny from the motor, thats it. Any questions PM me. This is a combo that you can drive before you buy!
For pickup only.
1750.00
located in Chattanooga Tennessee
http://classifieds.stangnet.com/show...?product=56302
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
