Mustang Forums at StangNet
04 Escape V6 2WD transmission flush
This is a discussion on 04 Escape V6 2WD transmission flush within the Other Auto Tech forums, part of the General Automotive Forums category; I was told it is just a drain/refill. is this true? why the hell would someone pay $200 at the ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-20-09, 10:05 PM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
I was told it is just a drain/refill. is this true? why the hell would someone pay $200 at the dealer if that is all that is required.
  #2 (permalink)
Old 04-21-09, 11:26 AM
greensvt21's Avatar
Official Member
The escape has a cd4e tranny, so there isn't a filter persay but a stainless non service ( accoriding to ford) screen thing.You don't drop the pan on this style tranny, there is a 3/8 style pipe plug on the side of the tranny. The real problem with a drain and fill is that you don't get the converter. The dealer doesn't just drain & fill they unhook the tranny lines from the radiator and hook them up to a tranny flush machine, the machine flushes the entire tarnny & conveter, they then add anti corrosive additives then the machine refills with fresh fluid. The machine service is by the far the best tranny service method out there for getting the entire tranny. That said I have never paid a Ford dealer $200 for this service on my taurus or explorer so shop around.
  #3 (permalink)
Old 04-21-09, 07:16 PM
bigcat's Avatar
thanks for the info. i called the local dealer again (the shops here are worse than a dealer for service) and was told again $200. I am headed to Omaha in a few weeks, so I contacted a few to see what they quote. hopefully substantially less.
  #4 (permalink)
Old 04-22-09, 01:52 PM
greensvt21's Avatar
Official Member
I just looked at my slip from my Ford dealer, it was $108.78 for a tranny service for my 06 taurus + my dealer gives the car a wash also. I'm thinking in these times they will do anything to keep customers happy. They beat all the local tire dealers also for tires/alignment for my explorer, you wouldn't have seen that in the old days $92 differance for the same service, something is way off with your dealers that's nuts.
  #5 (permalink)
Old 04-22-09, 08:11 PM
bigcat's Avatar
i called two dealers in Omaha. $175 and $171 were my quotes.
  #6 (permalink)
Old 04-22-09, 08:49 PM
greensvt21's Avatar
Official Member
I'm sure they must go by some giude for the service, I'm not sure if there is less room to get at the lines in the escape vs my taurus but it still shouldn't be that bad. still if they go by a guide the rate should be the same no matter what. The thing is the cd4e doesn't age well, there is post on here already for a contour that won't shift when warm, they used to have tss issues in the earlier years. If you can swing it getting the the machine flush is the way to go, like I stated it gets the converter. alot of times the issues with the cd4e is poor maintenance, fluid gets bad then valve body issues pop up, the sensors are easy to change but those are rare, unless you have the 2-3 hard shift.
  #7 (permalink)
Old 04-22-09, 09:03 PM
bigcat's Avatar
i have the money to do it, it just seems like too much for the service. i agree a power flush is the way to go.
  #8 (permalink)
Old 04-23-09, 06:57 AM
greensvt21's Avatar
Official Member
LOL. no I agree those prices you are getting out your way are high. I hope you can find a shop to do it at a reasonable price. good luck to you.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
