The simple answer is yes, you can. However you need to be sure that the original had a line level output and not a speaker level output. It will not hurt anything to plug the new sterio in to test it, you will just barely hear any sound if the original was speaker level. If that dosn't work, get an amp and harness out of a '93 premium sound car (some other years may have them, but I am sure the '93's did.). They use the square amp feed plug. I have the whole amp/ wiring setup if you need one.
