Hello, I just bought a new head unit and a wiring harness from ebay. In the past this has all been totally straight because I never had any amps and stuff like that.
So I'm wiring up the harness that came with the head unit to a harness I bought on ebay that would plug right into my factory mach 460.
The wiring diagram for the head unit says this
Blue - the manual labels a Remote Turn-On
Black (check)
Red (check)
Yellow (check)
Gray - Right Front (check)
Purple - Right Rear (check)
White - Left Front (check)
Green - Left Rear (check)
The harness I bought on ebay is actually 2 pieces (looks just like this
Ford Receiver Wire Harness - Additional images and video)
So here's where I'm confused. All of the wires from the dual harness except the Blue one are connected
Ebay Harness
Black (check)
Red (check)
Yellow (check)
Orange pair labeled as Dash Light Illumination and Dimmer Ground
Black /w stripe labeled as Amp Ground
Then the second smaller harness has
Black pair - Amp Ground
Blue Pair - Amp Ground
RCA Yellow/Red
Well the Dual HU has 3 RCA jacks on the back
Dual XHD7714 - Rear RCA jacks
labeled as
Front
Rear
Subwoofer
I don't know what I'm supposed to plug the RCA jacks into... Subwoofer?
I have no idea if the mach 460 has one I do know it has amps and I assume that because the Dual HU has a built in amp that is why there are no Amp wires on their harness.... but I thought the speakers were on the "otherside" of the factory amps, so even though I connected the wires to the speakers it still goes through the factory amp right?
