Mustang Forums at StangNet
302 EFI
This is a discussion on 302 EFI within the MII Discussion forums, part of the Mustang II category; I have a question about the 302 EFI. I was told not to mod up a 302 form 1986 and ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-26-09, 10:09 PM
KH! KH! is offline
302 EFI
I have a question about the 302 EFI. I was told not to mod up a 302 form 1986 and 1987, to use the one from 88 and up becuase the mod changes would hurt the engines performance and driveability. Does it really matter or did the guy I talk to blow smoke up my ass?
  #2 (permalink)
Old 03-27-09, 05:10 PM
Wart's Avatar
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
I'm just a puppy with EFI, so I may be wrong,
I believe '88 was the first year for Mass Air, but only in a few applications. I believe most applications continued using Speed Density.
I believe Mass Air adjusts to modifications (because it's an actual measurement of the mass of air being ingested) where Speed Density pretty much follows a "map" and is limited in compensating for mods, if it compensates at all.
What I've learned (I believe) is changing from SD to MA is not very difficult involving little more than the changing of the computer and valve body.
If I'm wrong I hope someone tells us about it.
fordfuelinjection.com/ seems to have a bit of info on this.
{link}Link to a table{link}
  #3 (permalink)
Old 03-27-09, 08:45 PM
Project 77's Avatar
Your very close Mark...88 was the first year for mass air in CA, all others were converted to mass air in 89. I converted an 87 Saleen to mass air with a kit from FMS. It's not very hard, kit includes a pigtail that plugs into the computer, a MAF meter with all the p[roper plastic and rubber pieces, and plugs to plug off the MAP sensor I believe.
  #4 (permalink)
Old 03-27-09, 08:47 PM
Project 77's Avatar
I forget which year it is, I believe 86 used flat top pistons, NFG when trying to use any kind of performance heads. I think it's 92 that used forged pistons, excellent for mods. Someone correct me if I am wrong
  #5 (permalink)
Old 03-28-09, 02:14 AM
KH! KH! is offline
So 86 and 87 stinks without MAF, convert to MAF and then mod, that's the rule of thumb?
  #6 (permalink)
Old 03-28-09, 02:24 AM
KH! KH! is offline
Quote:
Well Alcino used a 86 block and trick flow twisted wedge cylinder heads on his mustang II.
  #7 (permalink)
Old 03-28-09, 09:42 AM
Project 77's Avatar
that is correct if you try to mod a EFI car with speed density it can get sticky, SD does NOT do well with cam changes. As far as motors, you could use an 86 motor if the pistons are fly cut for the heads, and I know from experience you have to fly cut the pistons with TFS heads if you use a cam with a large profile.
  #8 (permalink)
Old 03-30-09, 11:15 AM
EFI
It is better to use a mass air setup as it responds better to mods. The speed density can be converted with a harness and computer if you already have one. But if you plan to do the GT 40 intake/Vortech route, the mass air flow works much better. You may have minor hood issues depending on spacers, but the rest pretty much fits. We recently installed one with a Tremec TKO in a car for my daughter. With less weight than a Fox 5.0 it runs well.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
