Mustang Forums at StangNet
i need some help
This is a discussion on i need some help within the 2005 - 2009 V6 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; i have an 07 mustang and I was recently changing the rear brakes on it. when i took the calibers ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-29-09, 02:31 AM
i need some help
i have an 07 mustang and I was recently changing the rear brakes on it. when i took the calibers off in order to put them back on with the new brake pads i had to use the c-clamp to pust the caliber back to fit over the new pads. now my back brakes arent working at all. theres no air in the lines everything is fine. but i found out that apparently you have to use some certain tool to push the caliber back on some newer model cars. what should i do. did i royally screw my calibers up by using the c-clamp to push them back withouth the tool or can this be fixed easy without alot of work. need some input thanks.
  #2 (permalink)
Old 03-29-09, 03:19 AM
StangGT1995's Avatar
have car, will race....wait, it doesn't run
You'll need new calipers, sorry. Brakes are one area where you definitely don't want to start rigging things to work, such as attempting a repair of a damaged caliper. You're not the first person to find this out the hard way, unfortunately. to though!
  #3 (permalink)
Old 03-29-09, 08:15 PM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
the rear calipers need to be rotated, not compressed. you now need new calipers. try OEM Parts & OEM Wheels - Original Equipment Parts from NewTakeOff for a cheap fix.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
