Mustang Forums at StangNet
Vortech V2 - Bad bearing?
This is a discussion on Vortech V2 - Bad bearing? within the Power Adders forums, part of the Power Adder and Race Tech category; Hi there. After 2 rebuilds under warranty (leaking seals), here's the sound of my Vortech V2 after a fresh install: ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Power Adders
Over 153,000 Members!!
Reply
  #1 (permalink)
Old 03-29-09, 03:35 PM
Official Member
Hi there.
Vortech V2 - Bad bearing?- Video
The first video is less than 1 inch away from the blower with 2 high-quality microphones, so the sound is a bit amplified.
Does it sound bad to you? Before sending the unit to Vortech, I don't remember hearing this "bee sound" mixed with the typical centrifugal sound.
  #2 (permalink)
Old 03-29-09, 07:00 PM
Official Member
mine has been rebuilt twice with in a year of having it, a bad bearing will make a screwtype of whine in your super charger i would check to make sure there is no oil in the front of the charger(intake side), if there is it could be a leaky seal or the impeller rubbing on the case, sometimes after a break in they change sounds i know that my buddys v2 makes a completely diffrent sound than mine (he also has fmic and a 2.89on it) i would just keep your ears peeled for a little bit to see if it gets worse
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
