Mustang Forums at StangNet
Really annoying beep noise
This is a discussion on Really annoying beep noise within the 5.0 Tech forums, part of the 5.0 Mustang category; I have a beeping noise coming from what sounds like behind the pass side dash area. It only does it ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-31-09, 08:26 AM
FOOT2DFLOOR's Avatar
Official Member
I have a beeping noise coming from what sounds like behind the pass side dash area. It only does it every now and again and quits after a few seconds, got any ideas what it may be? Thanks guys
  #2 (permalink)
Old 03-31-09, 08:50 AM
Airbag computer behind the radio. It beeps if there is a problem with the dash light to let you know there is a problem with the airbag system. Does the airbag light come on when you start the car? It could just be burned out, or you could have a wiring problem like with the clockspring in the steering wheel.
  #3 (permalink)
Old 03-31-09, 09:30 AM
Official Member
yea speaking of that the air bag light does flash. so what needs to be done to fix it? whats the clockspring you mentioned?
  #4 (permalink)
Old 03-31-09, 12:54 PM
dcurtis's Avatar
Official Member
I get that beep at start-up every once in a while, my airbag light does not flash though, it comes on when the key is turned though, so it does work.
  #5 (permalink)
Old 03-31-09, 08:37 PM
The clockspring is a spool of wire that powers the airbag and the functions on the steering wheel and is located in the column below the airbag. It is usually what fails due to years of turning the steering wheel, but you should check out the codes. Here is some info:
Mustang Air Bag Diagnostic Codes
  #6 (permalink)
Old 04-01-09, 01:02 AM
Shakerhood's Avatar
Official Member
Garage
Yep the Beeping is coming from the Airbag Diagnostic Monitor, it is the blue Box in behind the Climate Controls.
  #7 (permalink)
Old 04-01-09, 07:25 AM
Official Member
Ok cool ill check it out. It only beeps for a few seconds when I fire it up so that fix is gonna be put on the ol back burner for now. As long as it doesnt pop out for no reason it aint hurtin my feelins to much
  #8 (permalink)
Old 06-10-09, 06:32 PM
BLADDERMETAL's Avatar
Dang,i got the same problem,only i dont have an airbag and also i cant see the airbag light cause i got gauges a few years back and i covered the airbag light. I havent heard the beeps in 2 weeks though.But it was annopying as hell when i did,like a speaker with a bad connection sputtering beeps. How do i get rid of it if it comes back?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
