Mustang Forums at StangNet
tires
This is a discussion on tires within the MII Discussion forums, part of the Mustang II category; I have a 76 mustang cobra II and I want to know what is the widest tire I can use? ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-01-09, 07:39 PM
tires
I have a 76 mustang cobra II and I want to know what is the widest tire I can use? Thanks
  #2 (permalink)
Old 04-01-09, 08:00 PM
COBRAIIW's Avatar
Official Member
If you read the sticky at the beginning of the discussion page, you should find your answer, and some other alternatives.
Usable tire width is determined by a lot of factors.
  #3 (permalink)
Old 04-02-09, 12:32 AM
Dano78's Avatar
Best to choose a set of wheels or at least choose a certain rim diameter before talking tires. Depending on the rim's backspacing available will depend on how much tire you can stuff in there.
  #4 (permalink)
Old 04-02-09, 08:15 PM
I put a just the rim off a 86 or 87 mustang that was 15 x 7 rim and there seemed to be plenty of room????? It wasn't rubbing on anything when I turned it.
  #5 (permalink)
Old 04-03-09, 02:08 PM
Steel Steeds's Avatar
Official Member
Have you actually driven it with those wheels on it? I put '88 GT wheels on mine, and it seemed great - in the air. As soon as I put the car on the ground, the inside lip of the rim hit the control arm solidly. I'm running 1/4" spacers, and I ground the inside lip of the rim a bit too.
I've got 225/60R15 tires on it.
  #6 (permalink)
Old 04-03-09, 07:26 PM
The car just has one coat of primer on it as it was just stripped down to bear metal just days ago. I took off the white and blues stripes to make it black with the gold stripes. I think it looks much better.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
