Mustang Forums at StangNet
deck/lights not turing on help~!
This is a discussion on deck/lights not turing on help~! within the Sound Shop forums, part of the Mustang Sound & Shine category; alright i don't know if this is the right place or not but here i go. so my reading light ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-04-09, 12:13 AM
alright i don't know if this is the right place or not but here i go. so my reading light never worked till two days a ago for like 2 mins. so i was looking at it and it just turned off. then i pushed it back up and pulled it down and it worked again but it turned off again but this time my deck and int light want with it! i though it was just my fuse so i did not worry but when i want to find and change it there where know fuses blown. so what could it be??
  #2 (permalink)
Old 04-04-09, 10:41 AM
2BADSTANGS's Avatar
Official Member
Garage
What year 'stang is it? I'm gonna take a stab in the dark and gues that it is an older fox body with the aimable map light. I would pull the light down and check the connections behind it. The switches in those lights are notoriously crap, wiggle it and see if the light comes on. As for the rest of the problems, all of them going out at once makes me think fuse. Use a test light or meter and test the fuse, I've seen some that look good, but are in fact bad.
  #3 (permalink)
Old 04-13-09, 10:49 PM
Supradude26's Avatar
Official Member
Sounds to me like by you moving the light around, being that it is old and didn't work before caused a short in the curcuit and blew a fuse. All the lights that you are having problems with are on the same curcuit so a bad fuse would really be just about the only option, unless all te lights are wired in series, going through the map light first. If by moving it around you broke one of the wires it could cause the rest to quit without blowing a fuse, but it is very unlikely. Get a 12 volt test light and check the wires and all the fuses. I think there is a fuse box under the hood which is probably where the fuse is for the light.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
