Mustang Forums at StangNet
351w swap in a 76 cobra ll?
This is a discussion on 351w swap in a 76 cobra ll? within the MII Discussion forums, part of the Mustang II category; what has to be done for a 351w swap, I came across hedman headers that i guess is made specifically ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-06-09, 04:45 PM
what has to be done for a 351w swap, I came across hedman headers that i guess is made specifically for this swap,i don't know if they will work, i have a c4 trans in there right now,,and those headers aren't cheap there like $700.
  #2 (permalink)
Old 04-07-09, 12:56 AM
Steel Steeds's Avatar
Official Member
Swapping in a 351w isn't all that hard, if you use the factory exhaust manifolds. The two different headers available for the swap involve some work. I think (not 100% sure) that the Hedman's require the motor to be repositioned by using a plate. Another brand requires a battery relocation and some modification to the fender wells.
Also, depending on the intake/carb setup you go with, cutting the hood for clearance may be needed. If you go with a low rise intake, you can manage it without cutting.
Other than that, it's a drop in and go. No changes needed to fit the radiator, shroud, starter, etc. I did buy a bracket to adapt the 302 power steering bracket to the 351, but only because I wanted something that looked better than the hacked piece that was in there.
Good luck.
  #3 (permalink)
Old 04-07-09, 07:18 AM
swap
the headers that hedman offer, i'm pretty sure they go right underneath everything, so from the heads straight down, so it can clear, cuz i guess they cant fit through where the tranny is..and how does that whole motor plate thing work..
  #4 (permalink)
Old 04-07-09, 07:19 AM
COBRAIIW's Avatar
Official Member
The 302 oil pan will not fit the 351w, so the oil pan for the 351w must be used and modified to clear the rack and pinoin steering.
  #5 (permalink)
Old 04-07-09, 08:00 AM
what kind of headers are those,, will they clear my c4,,
  #6 (permalink)
Old 04-07-09, 01:29 PM
Official Member
Quote:
You're absolutely right, I totally spaced that. I had a 351w pan customized with a baffled 7 qt. deep sump. Cost a bit, but looks and works great.
I still have the original pan off my 351w if somebody wants it. Ready to go to work in any Mustang II with a 351w. It is NOT pretty, but it never leaked. It's basically the original Mustang II 302 lower part, welded to a 351w upper pan rail, and then beat on to make it fit. The previous owner did a lot of redneck engineering...
If anyone can use it, $20 plus shipping and the pickup is included.
  #7 (permalink)
Old 04-07-09, 01:58 PM
so what do u have to do get a 351w pan and take it to a shop and have a modified to fit cuz of the steering rack,
  #8 (permalink)
Old 04-10-09, 09:57 AM
COBRAIIW's Avatar
Official Member
The headers I used are old Blackjacks that came with the car.
The oil pan I modified myself. I cut out the section that wouldn't clear the steering, and welded a section in that did.
  #9 (permalink)
Old 04-10-09, 01:45 PM
Official Member
Quote:
That would be really expensive. Even with my new custom pan, after they mocked it up I brought it home and bolted it to the motor. It needed a bit more massaging to clear the crank. Then I dropped the motor in the car, and it needed more clearancing to clear the rack. I went through that process twice, but in the end if fit like a glove.
  #10 (permalink)
Old 04-11-09, 08:59 AM
351W Swap
I'm new to this website, so bare with me.
I've done this swap in 1980 Mercury Bobcat.
Headers - Hedman 85601
Motor Plate - Hedman 56066
Tatol Performance - F351 Modified Oil Pan/Oil Pump Pickup
I can send you pics.
E-mail at BIGRED77@q.com for your addy
  #11 (permalink)
Old 04-12-09, 09:45 PM
351 Swap
I do have a extra oil pan and oil pump pickup for the swap,
Form Tolal Performance
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
