Mustang Forums at StangNet
Stuck DIN Tool in stock head unit
This is a discussion on Stuck DIN Tool in stock head unit within the Sound Shop forums, part of the Mustang Sound & Shine category; i have a 1999 mustang without the shaker system. i have the normal one. I bought the removal tools but ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-26-09, 10:45 PM
i have a 1999 mustang without the shaker system. i have the normal one. I bought the removal tools but i think i pushed them in to far because the wont pull out and the cd player wont come out either. Can anyone help please?
  #2 (permalink)
Old 04-27-09, 03:41 AM
MustangLX-5.0's Avatar
Just on the other side of those holes in the radio there's a metal clip with 2 bent notches.One clip on each side.You only need to push the U shaped tool in about 2 inches or less.The tool probably isn't stuck.On each end of the tool,there's a small notch.That's there so it gets locked on the bent clips on the other side of the radio face.Those clips simply prevent the radio from sliding out.How far in did you push the tool?It shouldn't be able to go farther than 2 inches.The trick here is to slightly push sideways on the tool towards the edge of the radio.Push towards the edge and pull out.Pushing the tool sideways towards the radio edges forces the inside of the tool to push inward on the clip causing the clip to bend further inward.It may take some wiggling but it will come out.
Once you get it out,you will see what I mean....
  #3 (permalink)
Old 04-27-09, 07:34 AM
I have tried to pull it out hard enough that the tools are bending so i dont know why its not releasing. The clips did lock in, i felt them click and they wont come out
  #4 (permalink)
Old 04-29-09, 04:20 PM
j_lutter31's Avatar
Official Member
hmm, never seen that problem before, can you get the stereo out of the dash? or is it all locked in place.....
  #5 (permalink)
Old 04-30-09, 11:21 AM
only one side will start to come out. when i push it in, the other side will pop out. so idk whats wrong with it. is there any way to get in behind it?
  #6 (permalink)
Old 05-01-09, 11:04 PM
2BADSTANGS's Avatar
Official Member
Garage
Do you have the cd/ cassette setup or a pocket below the sterio? Either way remove the lower component and see if you can get to the release tabs. I f all else fails, remove your shifter bezel, the 2 screws below the sterio and there's 1 behind the lower opening. Once those are out, the rest of the center trim will release using "pressure clips". gently pull the edges until it releases. This will remove the whole assembly and allow you to acces the sterio release tabs.
Reply
Tags
cd player, head unit, radio
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
