Mustang Forums at StangNet
INJECTORS AND FUEL PRESS.
This is a discussion on INJECTORS AND FUEL PRESS. within the Fox 5.0 Tuning forums, part of the 5.0 Tech category; I was thumbing through the new FORD RACING catalog and had notice their take on what injectors are good for ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-28-09, 10:50 AM
WHT306's Avatar
Official Member
I was thumbing through the new FORD RACING catalog and had notice their take on what injectors are good for HP. I've heard everyone say that 19 lb inj. are good for 300 hp but thats at a 90-99% duty cycle and most safe duty cycles are 80-85% which would make the 19 lb inj. good for about 250 hp and this is bhp not rwhp.
Now you take the same calculation and the 24 lb inj. are only good for 326 hp at a 85% duty cycle. Is this why everyone seems to be using 30 lb inj. in most h/c/i combos?
The fuel pressure, everyone always states they are running for example 40 psi of fp
but there is a difference in fp and gauge fuel pressure, at the gauge the catalog said should be at 30 psi and when full throttle is hit fp should rise to 39 psi, so if you are running 40 psi at the gauge it would be hitting about 49 psi at full throttle because of the increase you would reach a rich condition correct?
Just tell me if i'm way off
  #2 (permalink)
Old 04-28-09, 09:12 PM
Foxfan88's Avatar
My Grandpa has great wood.
most injectors are flow rated at a specific pressure. alot of them (mustangs) are are 39 psi.
you set the base FP with the regulator with the vac line OFF. this simulates the atmospheric pressure at WOT.
whatever you set your base fuel pressure to is what you should see at WOT ( atmospheric pressure in manifold, only applies to N/A engines)
with the vac line attached. during idle and normal driving, the throttle plate is going to restrict airflow. the engine is going to want to move more air than the closed/slightly open TB will move. so the pressure in the manifold decreases.
the purpose of the FPR is to adjust fuel pressure to compenstate for the changing manfold pressures. the idea is to keep the same pressure differential across the whole operating range.... if you had it stuck at one pressure, while the pressure in the manifold change constantly while you drive. in a sense your injector flowrate would be constantly changing. making any sort of tuning impossible.
having locked out FP at 39 psi during idle would run rich, the pressure difference is so much more, more fuel will exit the injector for a given PW.
the exact opposite applies for boost. you want to make sure your FP increases under boost. you want 1 psi of FP for every one psi of increases manifold pressure. this is also to compensate for the changing pressure difference. except this time. if no FPR active. your injectors become smaller. since your manifold pressure would increase and it less fuel will leave the injector for a given PW. in a sense the extra manifold pressure is pushing back more on the fuel trying to come out of the injector.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
