Mustang Forums at StangNet
After market head unit fm reception problem
This is a discussion on After market head unit fm reception problem within the Sound Shop forums, part of the Mustang Sound & Shine category; I have instaled a EONON 646A after market head unit on my Mustang 2000 with the mach 460 system ,everything ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-29-09, 07:13 PM
I have instaled a EONON 646A after market head unit on my Mustang 2000 with the mach 460 system ,everything works perfect ,but I ahve a problem with the FM tuner reception ,when the car is stationnary it's ok ,but when the car is in the moove i lost the reception .Could it be a ground problem , the FM tuner with the stock head unit was perfect . The after market dvd player I have instaled have a antenna cable in his back. I have connected the antenna cable on the connector of this cable , I have noticed that the stock heaunit have the connector directly in the back of the head unit (directly in the unit) I supposed it make a better ground with the head unit.Does put a ground cable from the antenna ground to the body of the after market head unit will help resove the problem ,I need advice before starting this modification ,thanks in advance to you all.
  #2 (permalink)
Old 05-01-09, 11:15 PM
2BADSTANGS's Avatar
Official Member
Garage
Tighten the antenna, if that dosn't solve it, replace the sterio...
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
