Mustang Forums at StangNet
Rockford Fosgate Subwoofer upgrade kit install question....
This is a discussion on Rockford Fosgate Subwoofer upgrade kit install question.... within the Sound Shop forums, part of the Mustang Sound & Shine category; I purchased this to put into my Parnelli Jones Edition & was trying to install it tonight but I have ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-30-09, 10:55 PM
Question Rockford Fosgate Subwoofer upgrade kit install question....
I purchased this to put into my Parnelli Jones Edition & was trying to install it tonight but I have no idea which amp the harness plugs into??? There's two amp's by the drivers side door. I do have a different head unit in, a JVC one, so I don't know if this changes anything to make the subwoofer not work. I plugged the harness into one amp, then the other & I can't hear anything coming out of the subwoofer at all. It is getting power though, I unplugged it & plugged it back in & you can hear thru the speakers that it's getting power. I also don't have the install directions, so any input would be HUGE here. What am I missing? Is it because of the different head unit & it needs the factory one to work, is there another amp I should be plugging it into, or something else? What am I missing or doing wrong here???
  #2 (permalink)
Old 05-01-09, 10:55 PM
2BADSTANGS's Avatar
Official Member
Garage
We'll need more info. Year of vehicle, original sterio setup, model/ pics of aftermarket equipment being installed....
  #3 (permalink)
Old 05-01-09, 11:02 PM
Quote:
2007 Saleen Parnelli Jones Edition Mustang with the Shaker 500 system. Only aftermarket equipment is the JVC KW-NX7000 receiver that I replaced the factory original receiver with.
  #4 (permalink)
Old 05-02-09, 09:34 AM
2BADSTANGS's Avatar
Official Member
What is the model # of the RF kit your using? I'll try to find an install manual...
  #5 (permalink)
Old 05-02-09, 02:09 PM
I can't find a model # on the sub enclosure. Here's a link to the Punch upgrade kit though: Stage 3 Motorsports 2005-09 Mustang Rockford Fosgate 12" Subwoofer w/ Amplifier - Clearance
thats the kit I have. It was a kit that was installed on the Saleen Extreme's, but you can get the kit & do it yourself. Thanks for the help!
  #6 (permalink)
Old 05-02-09, 02:15 PM
Maybe I did find the numbers....this is what I found on a different website:
model #: UP-FMUSP12S
saleen #: 06-3002B14842
hope that helps!
  #7 (permalink)
Old 05-04-09, 10:17 AM
Here's the diagram from the Rockford Fosgate website for the Saleen mustangs.
Rockord Fosgate - Image Detail
Quote:
  #8 (permalink)
Old 05-04-09, 05:59 PM
2BADSTANGS's Avatar
Official Member
PM Me, with your email address, I'll send you the full install manual.
  #9 (permalink)
Old 05-05-09, 05:12 AM
Thanks for the manual! Only question I have is that in the instructions it says to plug into the amp above the drivers side kick panel, but there are two factory amps in that spot on my Parnelli Jones. I do have the Shaker 500....so which amp do I plug it into?
  #10 (permalink)
Old 05-05-09, 07:49 PM
2BADSTANGS's Avatar
Official Member
After reviewing the manuals myself, I would tend to believe your no sound condition is a result of your aftermarket sterio interface. Without being able to see the wiring behind your dash makes it hard to say, but it sounds like your amplifiers have been bypassed. Did you install the sterio, or do you know how it was done? There would be two solutions if the amps are bypassed... re-integrate the amps and install the sub as the manual describes, or use a known good signal (Coming out of your JVC) to feed the sub's amp.
  #11 (permalink)
Old 05-07-09, 04:52 AM
I put the receiver in myself, but I bought the wiring kit from Crutchfield so I'll call them today & ask to see if the factory amps are bypassed then with this kit.
  #12 (permalink)
Old 05-07-09, 08:00 PM
I called crutchfield today & they tech support really wasn't the greatest help in the world. All he told me is that the receiver wiring adapter that I used for the JVC radio just sends an "acceptable signal", as he put it, to the factory amp to allow an acceptable output from the factory amp, not necessarilly power to the amp. Since I don't know a ton about radios/amps/subwoofers, what exactly is he talking about? He really didn't give any helpful info for the Saleen subwoofer, or the two factory amps. So......what now? Any thing out of that paragraph make sense?
  #13 (permalink)
Old 05-09-09, 02:08 AM
2BADSTANGS's Avatar
Official Member
I am fairly sure i understood what you were saying. From the sounds of it, you are still using the factory amps. In your original post, you said you tried both amps and neither worked correct? If you made all of the connections as the manual directs you to and the system works fine except for the sub, I would begin to suspect that the sub itself is faulty. Use a meter (or at least a test light) to make sure that the sub is getting power. I dont mean to insult your intellegence, but you did try turning up the gain when it was hooked up, right?...
  #14 (permalink)
Old 05-14-09, 09:03 PM
LOL...ah, not insulted at all, but I finally got it working. I wired up the sub to a separate amp that I powered right off the JVC head unit & bingo....big time bass. The amp I bought is real small & I was able to hide it with the enclosure so everything still looks like a factory install. I guess the amp that's in the Saleen unit only powers up with the factory head unit & not a aftermarket unit. Everything works now....thanks for the help everyone!
  #15 (permalink)
Old 10-15-09, 09:25 AM
Instalation instructions
Hi
I'm based in the UK but have just purchased a Saleen Fosgate Sub for my 2005 Mustang.
Would you be so kind as to forward me a set of instructions so as I can fit the Sub correctly as nothing was supplied in the box.
Thanks in advance.
Trevor
ps there is a big following for the Mustang in the UK but they still choose not make it RHD it would sell like hot cakes.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
