Mustang Forums at StangNet
check engine light on....97 grand marquis
This is a discussion on check engine light on....97 grand marquis within the Other Auto Tech forums, part of the General Automotive Forums category; The check engine light went on (97 grand marquis) took the car to advance auto parts they ran the code ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-01-09, 09:51 AM
LB0193's Avatar
Official Member
The check engine light went on (97 grand marquis) took the car to advance auto parts they ran the code it came back as catalyst efficiency below threshold bank 1 p0420
The guy said it could be a bad cat or bad 02 sensors.....but he couldn’t give me a straight answer said I would have to take the car into a shop so they could scan it better...I thought that was the point of them having a scanner....anyway does anyone know exactly would this code means......I am thinking of just replacing the 02 sensors and hoping that’s it......what do u guys think.....
  #2 (permalink)
Old 05-01-09, 11:01 AM
DBMSTNG's Avatar
I fantasize about it being BIG!
if you know anyone with an Xcal or Livewire, just have them monitor/datalog the O2 sensor. you'll be able to tell by the reading if it is bad.
  #3 (permalink)
Old 05-01-09, 12:26 PM
squeak93's Avatar
Official Member
They guy that scanned it is correct. Its one or the other...
How many miles on the car/cat?
  #4 (permalink)
Old 05-01-09, 03:28 PM
LB0193's Avatar
Official Member
85k miles on the car
  #5 (permalink)
Old 05-23-09, 11:27 AM
I just had this problem with a '97 Mountaineer. First it started with O2 sensor fault codes, so I replaced the front O2 sensors and crossed my fingers. For about 25 miles, I thought all was well - then the CEL lit up again with the "catalyst efficiency" code - which it was NOT showing before.
I was about to replace the headers and cat-back exhaust parts anyway, so I went ahead and replaced the front cats and the rear O2 sensors; did it all at once.
There's a good chance that fresh O2 sensors (front and rear) will fix this - and if that doesn't do the trick, you're not out any money - the new sensors can be swapped to the replacement cat(s) / downpipe(s). Try your idea first before laying out the cash for new cats (the "EPA tax").
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
