Mustang Forums at StangNet
06 GT Grille to a 07 v6
This is a discussion on 06 GT Grille to a 07 v6 within the 2005 - 2009 V6 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; Does anyone know if an 06 GT Grille is a direct fit for an 07 v6? Mount points etc......
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-14-09, 12:30 PM
  #2 (permalink)
Old 05-14-09, 02:07 PM
GrayPony's Avatar
Official Member
Does not fit without modification. There are GT style grilles available for the V6.
  #3 (permalink)
Old 06-03-09, 08:51 AM
Actually I believe it'll be a complete swap if you change the grille and the front bumper, the only reason why I know is because two weeks after getting my 09' V6 I got backed into and had to replace my entire front bumper, I was going to switch to a GT, and that's when they told me that I would have to swap the grille too, I didn't do it considering I wasn't the one paying for it, from the dealership the front bumper for a GT brand new and painted will cost between 7 and 8 hundred I can't remember the exact cost though. This is of course just the bumper alone so I would look at some swap yards.
  #4 (permalink)
Old 06-03-09, 10:29 AM
Official Member
Hey Pegov99,
You can use the GT grille but it is not a direct fit. I put an 05 GT grille in my FIL's 05 V-6. I ended up cutting all of the tabs off the back of the grille and putting some 3-M double sided tape on the bottom of it. The sides of the bumper that go around the grill are wider on a GT. You have to squeeze the GT grille into the 6cyl grille opening in the bumper. Once in place, I drilled two small holes through the upper sides of the grille and through the bumper cover and secured it with pop-rivets. I painted them black and you can't see them. That has held the grille in place for a year now. I did not have to adjust the hood latch or hood bumpers at all. It does take a little more force to close the hood then before. The GT grille looks really good in the 6cyl bumper! He has had several compliments! I ordered the grille for his car from NewTakeOff.com. To make the foglights work, I used the harness from street scene. Great harness, and easy to use, but it will not allow you to run foglights and parking lights. I am sure that I can re-wire just haven't had the time. Hope that helps a little!
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
