Mustang Forums at StangNet
Problem w/ Procharger Install
This is a discussion on Problem w/ Procharger Install within the 2005 - 2009 V6 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; I'm almost done but absolutely can not get the piping from the blower to the intercooler to fit. Unfortunately ATI ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-24-09, 11:39 AM
I'm almost done but absolutely can not get the piping from the blower to the intercooler to fit. Unfortunately ATI is closed until Tues so any help would be great. I have a rubber 90, extended metal 45, and rubber 45 left to connect to the double 45, just like the instructions. I've tried it a couple different ways and no luck. Either the length or the angles are way off. Love to get this done for the weekend.
Thanks,
Matt
  #2 (permalink)
Old 05-24-09, 02:30 PM
afixer's Avatar
The Informant
from what i have heard keep everything loose till the end.
  #3 (permalink)
Old 05-24-09, 08:40 PM
Quote:
Thanks but everything is loose and no luck.
  #4 (permalink)
Old 05-28-09, 06:04 PM
solution
I called ATI and they told me the fix in under a minute. The discharge nozzle for the blower was pointed too far up. Every Procharger owner should know, if they don't already, that the housing for the compressor including the nozzle can be rotated a full 360 degrees independent of the gear housing. The reason is the P1SC is used in a lot of different applications. Loosen the 7 allen head cap screws around the compressor and rotate. I needed to rotate mine 45 degrees down to get it to fit. Done.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
