(imho)
Set the distributor to 10-12 degrees, no more.
Set the fuel pressure regulator to 38-40 psi at idle
Set the idle adj screw to 1 turn past first touch
Set TPS voltage to .95vdc or less DO NOT go over 1v
Make sure the MAF is the correct cal for the size of injectors that are in the car.
Check the daiphram in the FMU to make sure it's correct for the injectors and boost level of the car. (blower manuf. web site / tech line should be able to help)
If none of that helps, you could try a local tuner or remove the blower kit, but try the simple stuff first.
