Mustang Forums at StangNet
Mach 460 Head Unit Problems
This is a discussion on Mach 460 Head Unit Problems within the Sound Shop forums, part of the Mustang Sound & Shine category; So I had an aftermarket 12 disc changer in the trunk. I was removing it and taking out the wires ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-30-09, 11:32 AM
So I had an aftermarket 12 disc changer in the trunk. I was removing it and taking out the wires in the head unit area and the antenna wire hit an exposed where that was hooked up to the cd changer. When I put the head unit back in I got nothing, can't turn the radio on, nothing. So I changed the fuse which made everything work that had gone out, lights, odometer what not, but the radio still does not work or turn on...so I'm thinking that it is either an amp or something. I also tried to put another Ford radio in to see if it was actually the radio but that didn't work either. So if anyone could direct me in the right direction I would appreciate it.
Thanks
  #2 (permalink)
Old 06-08-09, 08:05 PM
DStang99's Avatar
Hello,
Did you check the fuse in the engine compartment?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
